Model 3 is charging only at 8 Amp
PatsFan
56
15
Boston
Hi
I have a 6-50 outlet and a 40AMP circuit breaker. I used to use a Chargepoint charger for charging my Model 3 and I used to get 32Amps max.
I bought a 6-50 adapter from Tesla today and started using my Mobile Connector, but for some reason my car won’t charge more than 8A. I went into settings to see if I can increase it but 8A is the max.
Weirdly , the letter T on Tesla mobile connector is in red and other letters are in green. I called the service center and they have asked me for times when I charged with 32A so they can compare logs.
Did anyone face the same issue ?
SMAlset
8,732
9,338
SF Bay Area
Gee I recall reading your other thread about your charging situation from before getting your car. Hope Tesla after looking at the logs can shed some light. The T and differing colors is strange and I don't recall reading about something like that before. Will follow to see the outcome. Wonder if it could be a problem with the adapter or the UMC (which I have read on here a few people in the past had). I didn’t even know the Tesla mobile connector handle could produce different colors. Love to see a photo of it. BTW what color is the T on the charging port area after you connect? You might try using your 120 adapter that’s in your kit and plugging it into your mobile connector and see what happens using house current.
if you've had notifications for charging set up in your phone app, might be helpful pinpointing those times.
I haven’t needed to use my UMC at home since getting the car since we have had a corded one plugged into our 14-50 recepticle and both of us use that to charge our cars. Thinking maybe I should pull mine out and check it now.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
Does the light by the charge port show green or is it showing orange when you plug in? If the UMC isn't inserted all the way, you can still charge but it will be at a reduced rate and show orange.
ngogas
1,725
1,106
Utah
Could be you outletnis wired wrong. I had that issue and resolved it myself by pulling out the outlet on the wall and making sure the 4 wires are correct.
PatsFan
56
15
Boston
I used regular charging household outlet and 5-15 Tesla adapter. It charges fine at 12A and all letters on mobile connector shows green. So either the 14-50 adapter is faulty or my entire power line is faulty.
Tesla customer care says the red T indicates that mobile connector is not getting enough power. So they asked me to check with my electrician, but I still don’t understand how my previous chargepont gives 32A on same outlet but Tesla is not getting enough power
Reactions: SMAlset
Petrlol
399
537
Ohio
I was thinking the same thing, but a 6-50 only has 3 wires. 2 hot and a ground. OP do you have a multimeter and are you comfortable taking a voltage measurement?
PatsFan
56
15
Boston
Only letter T is in blinking orange. 5 consecutive times blink, Tesla says its indication of low power
PatsFan
56
15
Boston
It has only 3 wires , 1 ground and 2 power. That same port works fine with chargepoint and gives me 32Amp
Zeolite
5
10
Minneapolis
This happened to me as well, with the exact same symptions. T flashes 5 times and charging is limited to 8 amps. IIRC the status codes are not the same among all the mobile adapters. A gen 2 flashing 5 times indicates an adapter fault. Once mobile service came out they swapped the mobile adapter and the 6-50 adapter. I have not seen a fault since.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
What's the color of the Tesla logo on to on the car next to the charge port (not the Mobile Connector)?
Ah, sounds like the OP probably has a defective MC then. Easy enough to fix.
PatsFan
56
15
Boston
Did they swap the 6-50 adapter or mobile connector which has TESLA blinking lights. My connector works fine with 5-15 adapter on a different outlet
Zeolite
5
10
Minneapolis
They ended up swapping both, but the technician didn't even try to determine which component was at fault. Mine also worked fine when using the 5-15 adapter. I speculate it could be a limp-home function of the adapter where it would allow you to charge <2kW even when some minor fault was detected.
SageBrush
REJECT Fascism
May 7, 2015
12,084
14,993
New Mexico
The other day I plugged in my J1772 with Tesla adapter and was limited to 16A charging instead of the usual 32. The alert on the car screen said the connection was poor. I presume that I either did not insert the plug all the way or there was some snow/ice that got in the way. I've changed by charging habits to times when the sun is out and the car is not iced over. Problem has not reappeared.
IIRC the T logo on the port flashed white instead of the usual green.
McFlurri
1,441
1,533
Kitchener, Ontario
I have had that issue a few times. But it flashes yellow and clicks constantly try to lock in the cable.
The problem is the locking pin is frozen so instead of just charging it.. it reduces the charge and blames it on you not seating the cable properly lol
Silver Streak
94
44
SoCal
Hi
Yup and solved. Adapter is slightly out. Reseated the adapter and back to 32 amps.
