Just received it, I will try and get this mailed out tomorrow Tuesday at the latest. I appreciate your business.Thanks. You got PayPal.
Do you have a discount for memorial day on these adapters ?Sale running thru the weekend
Sorry I’ve already come down to the lowest price and kept it there for months. There is a discount for multiple purchase along with a upgraded shipping. Buy 2 save $10Do you have a discount for memorial day on these adapters ?
I should be able to make that happen tonight, I was just tested the waters with the kit and even though it’s priced the same at what you could buy separately for it hasn’t really had much response. I’ll see if I can remember how I added the drop down to the listing tonight.Will you do a tire service kit for Model 3?
It’s a 21mm as it’s the same lugnuts as the S/X and the same 129FTLBS torque.Okay. Can you verify lug nut spec? TSportline has the Model 3 listed as 13/16 hex whereas your S/X kit is 21mm.
Ok I added the Model 3 to the kit, the price is higher as the model 3 jack pad is higher but in the kits I will give TMC members a $10 refund again just for this kit. Send me a message with your PayPal email and once you’ve bought it I’ll send you the $10 refund.Will you do a tire service kit for Model 3?
Safety is always firstHave you rotate tires with multiple of these? What was the process?
That being said and only because it’s a Tesla with the delicate underbelly I suggest two jack pads and two floor jacks.
If not for the soft underbelly of a field mouse and the angled factory lift spots and the intracul nature of said angled lift spot unlike most other cars where you could just life one corner and get the side to lift enough to just rotate that way.
There is too much down side to be....what’s the politically correct word? Frugal? And try the Macgyver it.
It’s not rocket science but rocket science went into making this car. So yah two jack pads and two floorjacks. It only takes a few minutes to do it this way and safety should always be first.
Yes that’s the safest way, I have not seen any info stating the pattern is anything but front to rear on the 3 as it’s built to date.So do one side at a time to swap front to back, and then lift rear and swap both tires?
