Vendor Model 3 jack pad adapter tire service tool
Discussion in 'Model 3' started by Murphy’s Law, Mar 4, 2018.
  1. Murphy’s Law
    Austin Texas
  2. ℬête Noire
    ℬête Noire Active Member
    TX
    Done. Great timing on this, thank you.
  3. Murphy’s Law
    Austin Texas
  4. Murphy’s Law
    Austin Texas
  5. Garlan Garner
    Garlan Garner Banned
    Chicagoland
  6. Murphy’s Law
    Austin Texas
    D258F768-067B-408D-88DF-1BB53269D423.jpeg 38F983A9-7918-4D91-8431-C123C88E710F.jpeg
    If your referring to a floor jack with the small lift saddle you really shouldn’t be using that jack anyway as the width of the jack wheels are too narrow and can tilt.
  7. Garlan Garner
    Chicagoland
    Exactly.
    I'm using the jack on the bottom where the head is round. Your jackpad is rectangular.
    BTW... your pics aren't showing up properly.
  8. Murphy’s Law
    Austin Texas
    In that theory all brake pads would be round.
    Under your vehicle Is a very small round lift area with creased weight bearing ridges, my lip pads are rectangular in that design to more evenly distribute the weight along those ridges and the round area.
  9. Lunares
    Lunares Member
    San Diego
  10. Murphy’s Law
    Austin Texas
    No. As in the pictures that small of a saddle won’t work. Lifting with a small diameter saddle even with a regular vehicle is risky. Always better to go with a wider one.
    This style works best. A 2-3 ton aluminum low profile flor jack.
  11. Murphy’s Law
    Austin Texas
  12. Murphy’s Law
    Austin Texas
  13. Murphy’s Law
    Austin Texas
  14. Garlan Garner
    Chicagoland
    That won't fit on the Model 3.
    The Model 3 doesn't have 2 jack holes.
    Lastly....you should make a round one with only 1 hole. Lots of newer jacks have round heads on them.
  15. Murphy’s Law
    Austin Texas
    This is the model 3 jack pad adapter, that original picture is a stick picture. If you would have clicked on the eBay link you would have seen that.
    And most floor jacks have round lift saddles, the design is to contact More of the lift area to more evenly distribute the weight.
  16. Nuclear Fusion
    Nuclear Fusion Active Member
    Outside a bubble
    I have a trolley jack, like the one you crossed out.
    Are circular rubber pad inserts common, to make the ‘cup’ area have a flush face?
  17. Wattzup
    Wattzup Member
    Florida
    Is this the recommended jack from Harbor Freight? 1.5 Ton Aluminum Racing Floor Jack with Rapid Pump®
    It is rated for 3,000lbs, but the weight of the model 3 is more than that?
    Curb weight (from Wikipedia)
    • Standard RWD: 3,552 lb (1,611 kg)[5]
    • Standard dual-motor AWD: 3,757 lb (1,704 kg)[5]
    • Mid-range RWD: 3,686 lb (1,672 kg)[5]
    • Long-range RWD: 3,814 lb (1,730 kg)[5][6]
    • Long-range dual-motor AWD (including Performance): 4,072 lb (1,847 kg)[5]
  18. Murphy’s Law
    Austin Texas
    Your not lifting the entire weight of the vehicle, I use both the 1.5 and 2.5ton depending on the need. The 2.5ton has a wider wheel base and rolls easier on uneven ground where the 1.5ton works best in tight spaces.
    If space is a limitation the 1.5ton will work. It I find myself using the 2.5ton note often.
  19. Murphy’s Law
    Austin Texas
    Flash sale thru Saturday
    10% off store wide on top
    of bulk discounts
    Buy 2 save $10
    Buy 3 save $15
    Buy 4 save $25
    While supplies last.
    murphyslawjackpads on eBay
  20. hoang51
    hoang51 Member
    NoVA
    Just stopping by to say this is a quality design jack pad. It survived accidental forgetfulness when I was rushing to go pick up my wife after swapping out all four wheels for the winter season (I was late picking up my wife BTW) about a week ago. I forgot one of the four jack pads under my Tesla Model 3, drove it for about 7 miles or so round trip and it survived not getting lost in the middle of the road somewhere. The magnet was strong enough to hold the jack pad onto the car for the entire short trip. I was expecting to lose the jack pad due to pot holes and irregular road pavements. Job well done on the design.
