Model 3 Lack of Grip on Curves/Changing Lanes
Discussion in 'Model 3' started by bopushaq, Feb 15, 2021.
  1. bopushaq
    bopushaq New Member
    Washington
    So I've had the Model 3 Long Range for about a year and a half now, and for a while, I've been noticing almost no grip whenever I am on any curve or changing lanes on the freeway. At higher speeds (anything above 70-80 mph), the car is drifting left and right/feels incredibly wobbly. I noticed this problem started around 8 months ago, but because of COVID, I hadn't been able to really start driving it again and testing until recently. When I took this to a Service Center, they told me nothing was wrong with the suspension, but I don't think the mechanic had enough time to test and really feel the problem even after I explained it to him.
    I have the 18" Michelin Pilot Sport All Seasons, which we replaced about 4 months ago, and 21k miles on the car.
    Should I try to book another appointment with a service center and explain the problem again? Or is there somewhere else I should go to see if they can fix the issue? I no longer feel comfortable driving the car, and I have to constantly fight it to drive well, but I'm no longer sure if this is an issue with my current driving abilities or an actual issue with the car. Any thoughts on this?
  2. sduck
    sduck Mr. Duck
    Nashville TN
    Sounds like something is up with your tires. Or perhaps it's an alignment problem. Definitely a service problem, make a new appointment.
    I'm not clear by what you mean by "an issue with my current driving abilities" - is there something here that might be a factor?
  3. XPsionic
    XPsionic Member
    los angeles
    Simple, ask (and might have to pay) for a 4 wheel alignment, and get the specs sheet printed out
    Ensure all 4 tires are inflated properly
    Make sure there's no oily substances in or around your parking area that you might be driving over
    Don't use armor all on your tires (not that you are, right??)
    Go rent/drive another car and see if u feel the same issue. You can test drive another Tesla for free and that should give you a good idea if it's your car or if it's in your head
  4. KenC
    KenC Active Member
    Maine
    Definitely check wheel balance on right, for the wobble and alignment.
  5. animorph
    animorph Active Member
    Scottsdale, AZ
    I don't suppose there's ice on the road?
  6. arghx7
    arghx7 Member
    Michigan
    Are you sure you’re not a bad driver who can’t handle a powerful car?
    • Disagree x 4
  7. Vines
    Vines Active Member
    Silicon Valley, CA
    Striking an object or curb can bump the rear toe out, I would agree to get a 4 wheel alignment and see where you are at.
  8. stopcrazypp
    stopcrazypp Well-Known Member
    Said everything I would say. Only would add maybe check for tire balance also (although a tire balance issue should show up in straight line also). Also the brakes might contribute too (esp. if traction control is running).
    The test drive suggestion is a very good one. Makes it so that it can be eliminated as a problem with OP's specific car or if it's just unfamiliarity with the driving feel.
  9. one2many
    one2many Member
    germany
    At about 110mph the car will lift or float a bit. Could cause a brown out
    at that speed.
    What was the question?
    • Funny x 2
  10. Peteski
    Peteski Active Member
    UK, Milton Keynes
    Obviously something is clearly not right here! Check tyre pressures and sidewalls for damage and any signs of tread de-lamination. Also worth checking tread depth across all 4 tyres to see if they are wearing evenly. If the tyres all look good then I would go back to the SC again. It should be the easiest car in the world to drive!
  11. EmOne
    EmOne Member
    Chicago
    I found the toe way out of wack on $25 alignment check (NOT with Tesla--they wanted $275 even if proved to be within spec) and had some related instability that was fixed when I replaced stock pieces with Mountain Pass and then had 4 wheel alignment. And by the way, I had no significant "hits" on the suspension; I think came that way from the factory. In all my years of driving, never knocked a car out of alignment (I'm 68). I still love this car tho!
  12. arghx7
    arghx7 Member
    Michigan
    Service center already looked at it and said no problem (see first post). Either they did a bad job of inspecting it (possible), or it's user error.
    My vote is user error or other misunderstanding of the vehicle.
  13. sduck
    sduck Mr. Duck
    Nashville TN
    One does start to wonder about posts like this from one post users. Especially when they post once and walk away without responding to anything further.
  14. holmgang
    holmgang Active Member
    eu
    The bold part is the most germane in the post. I suggest user drive the car more, under different conditions, and try to better understand and articulate the perceived behavior.
    I can relate that for a period of time I felt something similar.
    Scenario: Winter tires, correct pressures, correct load in car, car alignment and tracking was correct, road temp was standard winter, wind medium.
    Behavior: When driving at highway speeds (not extreme) car felt extreme susceptible to yaw. Like it easily rotated without any obvious external force or input. And the highly tightly-geared steering ratio means it felt twitchy to correct the cars angle as well.
    The effects were similar to bump-steer phenomenon (except car was going straight down the road and there were no bumps).
    Anyway, after a short period never experienced it again. Just a weird short moment where rear end of car felt sketchy
  15. mk677
    mk677 Member
    jacksonville fl
    in addition to all the good suggestions about wheels and alignments have you considered the reality that the model 3 is just a high performance sedan and not a high performance sports car? It could be that you are expecting the car to do things beyond it's capabilities.
  16. Gasaraki
    Gasaraki Active Member
    Syracuse, NY
    Have a shop check your tire wear and your alignment. Also the stock tires are sh*t and offer no grip.
  17. bopushaq
    bopushaq New Member
    Washington
    Thanks for the all the responses guys.
    When I meant current driving ability, I mean to say that there's a chance I am out of practice (I racked up 15k miles in 6 months prior to COVID, so I felt I had a very good control of the car), so that might be me convincing myself there's something wrong the car. I don't get this feeling driving any other car though, so I'm not sure.
    I really like the suggestion of test driving a car, I think that's something I will try, and then I'll return to the SC and ask for an alignment.
    Thanks again for the help.
  18. omarsultan
    omarsultan Active Member
    Northern California
    What did you drive before the Model 3 -- what is your frame of reference?
  19. ijoe13
    ijoe13 Member
    Seattle
    And to add to this question, how long have you been driving? As in how many years?
