This will apply to all model 3 RWD LR regardless of production date. (After software update for models already delivered)Does anyone know if this is retroactive to previously purchased Model 3s?
Mine went up and I received it the same month as you. Have you not gotten all the software updates?? Also, just as a side note: Tesla underestimated the range of the LR RWD by quite a lot originally. Right after they came out people reported getting 330 miles, so maybe Tesla is just moving the range closer toward the true number.Sorry to resurrect this thread but has anyone seen this increase in range in their Model 3 LR? Mine has never changed. I charge to 80% daily and has been showing about 251 miles (+/- 2 miles) since day 1 of ownership back in July 2018 (14,800 miles ago).
Tesla.com currently shows 310 miles range for both LR models available to purchase....
RWD only i believe.Mine has never changed. 278-ish on 85% charge - granted it is AWD. I assume this range is applicable only to RWD cars?
I did get a range “bump” after a software update. And as of recently notice that my 80 or 90% charge is not what it used to be. After performing a hard reset, as outlined from Mountain Pass Performance, the range immediately went back up when everything was powered back on. That lasted until I drove the car again. I have a LR RWD.
You could also have suffered some battery degradation. They say 5% the first year is normal and expected.My RWD LR was received 7/2018 and up until 2019.5.15 a full charge was around 308-310 miles. After that update, for a couple of months, the 100% charge amounted to 320-323. It has since then returned to 308-314. My driving style probably has a lot to do with it as I enjoy stomping on the go pedal. Also my upper charging limit has never been consistent as I don't yet have my HPWC installed at home. I had free charging at work (L2) so I normally added about 100 miles when I needed it, to get the range to at least 200 miles. There were several times when I made an effort to charge to 90-95% which yielded an estimated 323 miles at full charge. A couple of recent DC Fast charges using a CHAdeMO adapter to 100% made it only to 314.
512 miles?!My LR - AWD Model 3 has never charged above 500 km (512 miles).
It’s actually a different procedure as outlined in the link.Hard reset as in holding down the brake and the buttons on the steering wheel?
The record in a Model 3 is 606 miles on one charge. So, 512 is possible.Of course - 312 miles ... my bad
