The annual maintenance isn't required to keep the warranty.I wouldn't count on that. The Model S requires $600 of maintenance a year/12.5k miles.
I'd also like to do all my own maintenance. We'll see if that's possible.
Can you post an image of the maintenance schedule you were given?Don't know if this has already been stated somewhere but....
When I picked up my 3 on Monday a maintenance schedule and cost was given to me at the same time. They are following the Model S rwd plan and costs exactly.
And brake fluid. With the amount of regen that is capable (and I assume most people will put it on the highest setting), you should not need to use your brakes nearly as much as an ICE. It seems like your pads would barely be used after a year or two. The fluid shouldn't need replacing if the brakes aren't being used much, right?I'd like an explanation for why battery coolant needs to be replaced more often than ICE coolant and why drive unit fluid needs to be changed more often than ICE transmission fluid. I had hoped Tesla would fix this for the Model 3. I'm not sure how they can claim that EVs are lower maintenance...
That seems like a maintenance schedule for the S/X....different than what's in the Mod 3 manual....see page one of this thread.Here you are. Sorry for the poor quality.View attachment 295545
Ha! That what it says! Seems like a lot of $ every year for what they are doing.
For normal road use, frequency of brake application doesn't have much to do with brake fluid life. I have personally observed that changing fluid every two years as required by BMW/Mini improves brake feel significantly for my street-driven vehicle. This is important for emergency situations and for descending long mountain grades. More information here:The fluid shouldn't need replacing if the brakes aren't being used much, right?
How is year 3 $475? Are the wiper blades made of Vibranium??
That’s strange. There is no such maintenance schedule in the Model 3 owners manual— only tire rotations every 6250 miles (where did they come up with such an odd number?), brake service every 2 years/25,000 miles, and battery coolant every 4 years/50,000 miles. No mention of annual service in the Model 3 owners manual, which surprised me as I was used to doing one with my S. Could this be something the San Antonio service center put together on its own?Don't know if this has already been stated somewhere but....
6250 miles is ~10000km...
Correct, the maintenance/service plan is not required during the first 4-year new car OEM warranty period, only during the ESA period.Required for ESA coverage not warranty.
For the Model S ... everything else including the maintenance plan seems to mirror the S and 3.I'm assuming that's from the ESA for an S? Or has Tesla finally published ESA stuff for the 3? Last I heard they hadn't yet...
