But the question is, where is the brake fluid reservoir located on the model 3.
Under the hood like a normal car. (Yeah it is under another cover you have to remove.)
That's a terrible method. The fluid doesn't circulate. It's a single line going to each caliper so the fluid that's near the caliper is never going to be changed.Someone once gave me a tip on how to maintain the brake fluid without bleeding brakes. He would basically take a turkey baster to suck out only the brake fluid out of the reservoir and fill up with fresh fluid. The clean fluid will mix with the rest of the fluid in the system. He does this before the required maintenance schedule and regularly. As a result, there is always fresh clean fluid because the stuff circulates. And thus, no need to bleed the brakes or flush out the brake fluid in its entirety. I don't have my M3 yet. But it seems this would work with the M3 as well?
The annual maintenance isn't required to keep the warranty.
It'll be interesting to see whether Tesla does the Annual Money Grab approach with Model 3 as with S/X ('required' annual maintenance, where nothing of value actually gets done). I've driven a Nissan LEAF for 6.25 years and it has required zero trips to the dealer other than to swap out the Gen1 battery pack under warranty. Zero. It has been impossible to spend money maintaining the Nissan LEAF. I'd expect similar with Model 3 (but I do expect warranty repairs with Model 3, based on S/X track record). Hopefully Tesla doesn't decide to demand $300-600/yr from me in order to keep the warranty in effect.
10 sec Google search here: Vehicle Warranty | Model 3Hello Obenjamin -
That is all I really care about. I just want to ensure that warranty is not void. Any proof to the pudding with that comments?
When I pick up my M3, I ask the delivery guy when should I bring the car in for services? The responses was you don't have to and only if want to or feel like you need servicing. He did mention warranty will be honor even if you don't do maintenance.
Lots of opinions in the thread. Just curious what is the norm in generally how everyone is handling this.
Highlight area: If I choose not to service my Model 3, will this void my warranty? We highly recommend that you service your vehicle as listed in the Model 3 Owner's Manual, which is available in your Tesla Account and on your touchscreen. If you do not follow Tesla’s Model 3 Service recommendations, your New Vehicle Limited Warranty will not be affected unless you receive a service alert and do not promptly contact Tesla to schedule service and that results in greater harm to the vehicle.
Hey guys, I've just scheduled my service follow the MS and MX maintenance plan and one of the staff emailed me back to ask me to cancel the appt cuz they have different plan for model 3 and finally thanks God they sent me the plan. Please see the attached file.
Very helpful thanks.Hey guys, I've just scheduled my service follow the MS and MX maintenance plan and one of the staff emailed me back to ask me to cancel the appt cuz they have different plan for model 3 and finally thanks God they sent me the plan. Please see the attached file.
If I had to guess, it’s the amount of channels in the battery, the thickness of the channel walls, and the lack of long term data.Why does Tesla coolant only lasts 50k miles while ICE vehicles have coolant that lasts 110k miles? Intuitively it seems like it should last longer since it's not exposed to high temperatures but maybe it's the opposite...
Could be but radiators have very narrow channels too. Of course radiators only seem to last 120k miles before they start leaking from the plastic endcaps so I guess I wouldn't notice if they were getting clogged. The Chevrolet Bolt doesn't require a coolant change until 150k miles.If I had to guess, it’s the amount of channels in the battery, the thickness of the channel walls, and the lack of long term data.
Corrosion of a cooling tube in the battery would cause a pretty major problem. Not as thick as a metal motor block.
And this is a total guess.
