I have a Model 3 Performance on order. It will be daily driven, no track use. I want to feel connected to the road, in the same way you feel when driving a 911 - sharp handling and feeling like the car does exactly what it’s instructed to do (I understand I can’t mimic that due to the laws of physics, but want to get as close to that as I can).
Once the car is setup correctly, I don’t think I’ll need the ability to adjust. I’d like to run one set of wheels rather than having to switch. My climate has winter temps ranging between 3C and 11C.
In order of priority:
Handling/road feel/responsiveness
Comfort/quiet ride
Looks
Efficiency
I’ve read and re-read the countless threads on here, there is so much info to get my head around I don’t know where to start. There are some incredibly knowledgable folk in here who I’m hoping can point me generally in the right direction and save me from making (expensive) mistakes.
Rims/Tyres
I’m thinking either 19x10 +35 with 275/35 rubber like MPP run on their car, or 18x9.5 +22 with 265/40 rubber per below images. Rims will be Advan RG3 or GT.
Tyres I’m thinking will either be Pilot Sport 4S, or A052, or RE71R.
Flush fitment preferred for looks if possible, but performance more important.
Suspension
I’m thinking of going the MPP sports coilovers to get the ride height and damping where I want it.
Questions:
- Pros and cons of each wheel size?
- Pros and cons of each of the three listed tyres?
- MPP have a heap of other suspension arms and items available, all listed below. Which are recommended, and which are absolutely must have?
- Is there anything else I should consider, or have missed?
Front upper control arm
Rear spring arm with sport springs
Sway bars
Compression rod bearing (caster adjustable)
Rear camber arm
Solid front lower control arm bearing
Rear toe arm
Rear trailing arm
Rear traction arm
Thanks
