I have a M3 MR (they were 264 miles I think). 11 months old, 6000 miles. It now shows 241 miles when full, and 217 miles when charged to 90%. That's about 9% degradation in less than a year. Should I complain, or is this normal?
My model 3 says full at 210 miles
V10 and Battery "Degradation"
Battery Degradation Scientifically Explained
Range drop
Suspicious range numbers
90 percent charge low?
100% charged with 204 miles. Lemon law applies?
100% charge range of SR+ at 224...new order of same car is 250 advertised
Service appointment for 12 month old Model 3 for range loss /invoice for out of warranty inspection?
2.2% battery degradation at 11k miles
Battery Degradation and Rated Range explained
Almost 15% range loss Model 3 Awd
Poll: LR battery degradation @ 3k miles
Model 3 Performance Battery Degradation One Month (Story)
I love this car, but.....
Battery degradation or BMS error?
Tesla appointment for battery health concerns mysteriously disappeared
Do batteries contain a “buffer”? My kW usage doesn’t match pack size
Mid-range changes in range or battery degradation
Range on midrange reduced to 219 miles
Model 3 Long Range Rated Mileage at 310 or 325?
TeslaFi - Battery Degradation Reports (upload your data)
Wh/mile specifically for M3 LR AWD with 19" wheels
Standard actual battery range or defective battery?
9% lower after only 6k miles seems a bit out of the norm. Try changing up your charging strategy.I have a M3 MR (they were 264 miles I think). 11 months old, 6000 miles. It now shows 241 miles when full, and 217 miles when charged to 90%. That's about 9% degradation in less than a year. Should I complain, or is this normal?
Your battery hasn't degraded. Everything is normal. Don't forget that you will be getting less capacity during the winter months.
Mid-range here. I'm at 11k miles, and down to 248 miles total range. 6% off of EPA rated. Everything I've read here is that it's normal, but there was just a huge survey done by Bloomberg that shows I am an outlier.
Go to the bottom of this page for the chart. I am one of those dots at the bottom:
Bloomberg - Battery survey
This is cause for concern, and in direct conflict of all the posts here that say "it's normal"
one year old model 3 mid range has 3333 miles and fully charged only gave me 221 miles today. was contacted by tesla stating that this was normal and within parameters for similar cars. so baically i lost over 40 and its OK not an issue people, theres nothing to see move along.
MR here, march 2019 build, 6800 miles, showing 221 at 85% so projecting out to 259 at 100%. Typically charge 60-70 range daily, once a month or so a trip runs it down to ~10% from 80-85 %.
Bloomberg's data is self-reported. So, one has to consider that the owners are somewhat self-selecting. Stats gets the data from the car.Mid-range here. I'm at 11k miles, and down to 248 miles total range. 6% off of EPA rated. Everything I've read here is that it's normal, but there was just a huge survey done by Bloomberg that shows I am an outlier.
Seems extremely low for 3k miles. One of the more egregious differences. As mentioned earlier, try changing up your charging strategy, set your limit lower if you've been setting it higher; and vice versa.one year old model 3 mid range has 3333 miles and fully charged only gave me 221 miles today. was contacted by tesla stating that this was normal and within parameters for similar cars. so baically i lost over 40 and its OK not an issue people, theres nothing to see move along.
I am the one in the 15% percentile of degradation after 11k miles. I normally charge to 80%, but only use about 5-10% of it in a day. So it goes under 70% maybe once a week? Maybe I should try charging to a lower max %, like 70%? My only issue with this is that Tesla themselves say to charge to 90%.
