I am the one in the 15% percentile of degradation after 11k miles. I normally charge to 80%, but only use about 5-10% of it in a day. So it goes under 70% maybe once a week? Maybe I should try charging to a lower max %, like 70%? My only issue with this is that Tesla themselves say to charge to 90%.
Since you're showing unusually high early deg, I would take more extreme action. Go for optimal charging. Since you use 5-10%, then set your charge to 60%. Try that and see if there's any difference. If things do improve, then you can inch that up to 70% and if that works, then 80%.
The 90% is considered okay, but it's not better than 80%. Any choice is a tradeoff between battery longevity and battery usefulness. Elon thinks that the slightly worse deg of 90% is a fair tradeoff for the greater convenience. Your battery for some reason doesn't seem to like it, so change up your strategy.
