Model 3 new USB C center console data hub from model Y?
Discussion in 'Model 3' started by AxlxA, Jun 23, 2020.
  1. Durzel
    Durzel Active Member
    Bath, UK
    Thanks both, that’s super helpful. The video is exactly what I was looking for! Thanks!
  2. dickyt
    dickyt New Member
    Japan
    @Durzel @smatthew I want to say thank you for investigating the retrofit adapter!
    I am planning to move my SSD inside the console, so my footage can be safer even if somebody broke in my vehicle. My vehicle comes with USB-C, but I am afraid that hooking another USB hub and SSD before the Tesla Hub will not have enough current/voltage. Thanks for your valuable discussion here, so I could plan on wiring the power supply via the connector.
  3. robl45
    robl45 Member
    Anyone know where I can get the adapter? Just picked up the parts which are useless without adapter and it's sold out
  4. robl45
    robl45 Member
    Anyone have a couple of adapter they don't need? Really hoping to get this swapped before my my long disney drive in 3 weeks
  5. robl45
    robl45 Member
    Seems that mouser is out of these parts. Anyone know where else to get these? I'll just put it together myself if I can source them easily.
  6. BioSehnsucht
    BioSehnsucht Model 3 LR
    DFW, TX
    #346 BioSehnsucht, Feb 26, 2021
    Thanks to newly discovered (for me) Octopart.com, by way of Google, I might have found all the parts - sort of.
    I was unable to locate a source for the TE Connectivity MQS connector housing, except at Farnell (UK), so if you can get someone to order it in the UK then ship it to you, that would work, but they don't ship outside of the UK. There's also some non-authorized resellers listed but all their pages are request for quote pages, so good lucky getting anything in a timely fashion from them, if at all at the low quantities any of us would want. And since the Metri-Pack 280 pins are only available in quantities of 250, perhaps it makes sense to then arrange for multiple connectors from the UK via whomever handles that too, then you can resell the extras of both things?
    Links for the parts (keep in mind some may be regional only, i.e. Farnell is UK and won't ship to the US) - I listed the Octopart link first which will itself be a list of many possible sources, then I listed some in stock links for actual stores.
    TE Connectivity MQS series connector parts
    Part 936121-1 (housing - 1 per adapter)
    936121-1 TE Connectivity - Connectors - Distributors, Price Comparison, and Datasheets | Octopart component search
    Farnell (UK ONLY): https://uk.farnell.com/te-connectivity/936121-1/automotive-conn-housing-plug-4pos/dp/3134644
    Part 1-928918-1 (pin - 4 per adapter)
    1-928918-1 TE Connectivity - Terminals - Distributors, Price Comparison, and Datasheets | Octopart component search
    Newark: https://www.newark.com/te-connectivity/1-928918-1/contact-pin-24-22awg-crimp/dp/84R0783?ost=1-928918-1
    AVnet: Avnet: Quality Electronic Components & Services
    Aptiv (formerly Delphi) Metri-Pack 280 series connector parts
    Part 12052856 (housing - 1 per adapter)
    12052856 Delphi - Automotive Connectors - Distributors and Price Comparison | Octopart component search
    12052856 Aptiv - Distributors and Price Comparison | Octopart component search
    Mouser: https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/12052856/?qs=/ha2pyFadujH2cYK3jYvFUjYYj9lz7hj%2BS/srsg8zqY=
    Part 12052217-L (pin - 4 per adapter)
    12052217-L Delphi - Automotive Connectors - Distributors and Price Comparison | Octopart component search
    12052217-L Aptiv - Distributors and Price Comparison | Octopart component search
    TTI: https://www.tti.com/content/ttiinc/en/apps/part-detail.html?mfrShortname=DCS&partsNumber=12052217-L (minimum order 250, but that's still only about $40 and you could potentially resell them on to others)
    Part 15324456 (lock - 1 per adapter)
    15324456 Delphi - Automotive Connectors - Distributors and Price Comparison | Octopart component search
    15324456 Aptiv - Distributors and Price Comparison | Octopart component search
    Mouser:
    https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/15324456/?qs=/ha2pyFadugCQ39QZoZWsP2APWwKs6g%2BEfeWGJcvyMg=
  7. BioSehnsucht
    DFW, TX
  8. robl45
    robl45 Member
    Can anyone tell me how to remove the original connector from the vent? looks like there is a slot where I need to put a screwdriver in to get it apart?
  9. robl45
    robl45 Member
    Thanks to Cypho sending me some parts, I have completed my adapters. I've done this type of stuff a lot over the years, but not with connectors so small. I would recommend getting it assembled from someone if that is an option.
  10. robl45
    robl45 Member
    I"m curious as to what tesla is doing if someone damages their rear vent or there is an accident and it gets damaged or whatever, are we just ordering the new model 3 vent part or is this the only part? If so, Tesla must have a way to do this.
  11. phtp
    phtp Member
    Vancouver
    I would imagine Tesla would still carry the old part number. If it gets to the point where it's no longer available they might just tell you too bad so sad. Other makers do the same thing since by then you will be out of warranty.
    In accidents, it'll be something you work with the insurance adjuster. The repair shop will most likely find junkyard parts or source it however they want to source it.
  12. robl45
    robl45 Member
    I have dealt with scenarios like you talk about over the years, but doesn't tesla have to make parts available for 10 years? Most model 3 are 4 years or less. That is a long time to keep this part sitting around. Would make much more financial sense to just have an adapter.
    Also, What about warranty work,, my service center sucks, I mean seriously I could get better service at the local Honda dealer. Is anyone removing the parts if they go for service or they just hoping Tesla won't complain? My service center would probably make the excuse that I changed the rear vent and that is why the wipers aren't working.
  13. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    I have never found any requirement for parts being available for any specific period of time. (Other than they have to have parts to cover warranty repairs, otherwise they have to replace the vehicle.) But even then I don't think the parts have to be the same version/design.
  14. phtp
    phtp Member
    Vancouver
    I doubt they would keep a part for that long. If there is a warranty repair they will figure out a way to fix it, even if that involves splicing and taping things. I had a hood tab that somehow melted from the body shop. Tesla was supposed to order a new one, but it was discountined and they couldn't. The mobile service guy said he ended up grabbing one from his boss's car.
    In regards to the service center part, that won't change, that's pretty much their MO everywhere.
