ord3r
Both rwd. Should probably just add to trackerRWD, AWD or P?
That would be helpful for everyone. Thanks!Both rwd. Should probably just add to tracker
Great! You are in the 92 percent that did not participate. But, 8% of Tesla buyers have been participating and Troy has been extrapolating from there.I got my VIN yesterday, and my friend got hers last week 43xxx for both. Neither of us are in the tracker, nor is anyone I know using the tracker.
I was 7/1/17 reserve, she was day 2 (4/1/16) reserve.
Looking at the VIN Queue 2 tab, I'm realizing that none of this is capturing original reservation date. Was that ever captured? For my config (AWD, Deep Blue Metallic) there are about a hundred people who all configed in the few days after the config was opened up, and I'm not sure we have a good sense of how Tesla is balancing original reservation date versus configuration date.
@Sneakerbuddy,
We will find out the accuracy of the production and delivery estimates in a few days. Here are my estimates:
- 27,443 Model 3 production in Q2 2018 (Expected accuracy: 95%)
- 23,756 Model S+X production in Q2 2018 (Expected accuracy: 92%)
- 15,814 Model 3 deliveries in Q2 2018 (Expected accuracy: 85%)
- 11,269 Model S deliveries in Q2 2018 (Expected accuracy: 85%)
- 9,674 Model X deliveries in Q2 2018 (Expected accuracy: 85%)
The actual numbers for the first 5 items will be released by Tesla on 3 or 4 July. I will calculate the accuracy and post it here. I don't think Tesla will release the last two items but I added those just in case they decide to release them too.
- 14,512 Model 3 deliveries in the US in Q2 2018 (Expected accuracy: 85%)
- 1,302 Model 3 deliveries in Canada in Q2 2018 (Expected accuracy: 85%)
Hi @Troy - Any color on your July delivery estimate of 6.3k as of July 27? Seems a bit low given 11k in-transit on June 30 and this tweet?
@schonelucht, VINs might be affected by many things. I recommend looking at the table on the Production tab that shows monthly numbers. That's a lot more accurate than what the reported VIN numbers suggest. The table shows that production has increased every month without exception. Production in May was higher than April, June was higher than May and July is expected to be higher than June. Same with deliveries.
Hi, everybody.
I have removed the July delivery estimate because it relies on the sample rate which has dropped sharply this month. People who placed an order recently without a reservation are a lot less likely to know about this spreadsheet than those who have been waiting since 2016. We already knew that but now I have looked at the production numbers closer and it suggests that the sample rate might have dropped from 7.3% in June to 2.1% in July.
The production estimate for July is 15,205 units and there are hardly any people left waiting for delivery. Look at how this red line dropped sharply in July. It's heading to zero. It will move closer to zero when I clean up some of the outdated data.
I have now separated RWD and AWD VINs. There is currently only one VIN chart that shows RWD VINs. The other VIN chart will be added later when there is more data. However, I suggest checking out the new production tab. I have just updated it within the last hour. It works based on the separate VIN chart idea.
Hi, @shiz. I guess you are using the username Shots in the spreadsheet. If that's not you, you can enter your data here. Then wait for 30-60 minutes and find your username here on the VIN Queue 2 tab. This chart gives you an idea of what's going on.
The table on the right is for the Model 3 P, Midnight Silver Metallic. 14 people have entered their data. 4 of them have received their VINs. There is some randomness with VIN assignments. For example, the two users who configured on 27 June waited for 22 and 24 days for the VIN and somebody who configured on 16 July received their VIN only after 4 days but somebody else who configured on 16 July has been waiting for 12 days. Looking at the VIN rate for P orders, I estimate that you will receive your VIN within 2 weeks.
Tesla is trying to increase AWD production. Looking at the VIN data, I can see that they have switched one of the general assembly lines from RWD to AWD on 19th July and they are making at least 178 AWD Model 3s per day but this number could be higher than I'm calculating with limited AWD data.
