Model 3 Owners: Who Here Has Trickle-Charging Only/No Home Charging?
If you're a Model 3 owner without L2 charging, what do you have?
  • Total voters
    48
F14Scott
198
311
Houston
If you are almost out of amps at your panel, a relatively easy and inexpensive way to have plenty of charging smash for all but the most extreme cases (like returning home empty and needing to immediately press out on a 50+ mile drive) is:
Have an electrician wire a dedicated 6-20 (20 amp, 240VAC) outlet, which places only 5 more amps' draw than your standard 15 amp, 120VAC wall outlet, and get the 6-20 adapter for your Mobile Connector. Cost for a new breaker, the wire, the outlet, installation, and the adapter will probably be under $300.
That setup gives a TM3 15 MRPH, or 180 miles per 12-hour night. 20 amps at 240VAC is 2.67 times as much flow as 15 amps at 120VAC ((4800W v. 1800W), and your car, which uses some of that flow for vampire loads while you are charging, will use a greater proportion of the bigger flow for actual battery filling, hence the triple charging speed, relatively.
Reactions: AdamMacDon
RayK
1,835
1,786
San Jose, CA
I voted "no home charging/Supercharge only", mostly because I'm lazy. I have had a HPWC in the box for many months; just lack the motivation to install it in my garage. This was mainly due to having employer-provided free L2 and DCFAST options up until last September when they stayed and I left. Although I have gone back a couple of times and charged there when I was in the neighborhood. With the recent COVID-19 lockdown, I'm driving even less so a quick top-off at a local SC once every two weeks is fine enough for me for now.
Reactions: lUtriaNt
