So THIS ARTICLE makes a few interesting claims:
-60kWk base pack, 75kWh upgrade capacity
-Only 4 modules (assumed 60, implies 5 modules for a 75kWh pack?)
-Modules made up of 7 sections
So a few assumptions for the sake of this speculation:
-The model 3 packs of this size will operate at similar max voltage as their model S counterparts (~350V), meaning existing superchargers, etc... will remain compatible...
-The "section" in a module is also a set of parallel cells in series with other sections
-Cell voltage is max 4.2v
So, if that article is taken at face value, that would be 4 modules of 7 sections, for a total series pack voltage of only 118V. Seems unlikely.
If it were 8 modules as per the original presentation renderings, with 7 sections per module that would still only be 235v. Still seems low.
It would take 12 modules of 7 sections to hit 353 volts.
A 10 module/7 section pack would be 294v. That might be reasonable, but 10 modules matches neither rendering nor that article description.
I have to question the validity of that article, or my assumptions are way off...
