djgarrett21
All these technicians can't be wrong about the battery...or are they all really that uninformed?
These are literal quotes copied from a statement Jerome Guilen made in 2014 regarding the range estimator in the early Model S cars:NEW NEWS from Tesla Executive Customer person - I think it means that it doesn't count driving style, but DOES lose accuracy based on charging level...so you have more miles than than indicated, i.e., maybe you could drive more miles than expected from range estimate and wh/mi; somehow it would slide the estimate non-linearly as charge decreased:
We have found that in cases where the battery is consistently charged to a lower state of charge, between 60-80% capacity, estimation becomes less accurate and tends to underestimate the true capacity of the battery. The result is an incorrect reduction in the displayed range estimate. This does not affect the true range of the vehicle, as the end-of-drive conditions are based on real-time battery measurements of reducing battery power, rather than software estimates. In any case, we recognize the inconvenience and negative user experience associated with this incorrect and reduced range estimate, and we are developing more accurate estimation algorithms which will be pushed over the air to the car when available. In the meantime I would recommend scheduling a service appointment through your Tesla account online and our technicians can assist in a kind of re-calibration for the range estimates you are current seeing.
Best regards,
XXXXX, Executive Care
A Senior Tesla Executive's Comforting Answer to Concerns Re: "Loss of Range" | Tesla
So, it's a Battle of The Tesla Technicians . . . . . The "senior" technician I spoke with insisted that Rated Range does not take into account driving habits/history, at all. He pointed to the Energy app and told me that's where I should go, if I wanted to see how recent driving habits were affecting my range (the 5/15/30 miles history options). He also pointed out that the Rated Range indication on the Energy Chart is there specifically so you can compare your range based on the past 5/15/30 miles of driving habits, to the rated range which is a constant and not based on driving habits.Service ran a remote diagnostic on mine and said everything is good. He also insisted driving history is accounted for in the battery indicator range.
I usually drive about 25km a day and have the charge set to 75% midnight charging.
I don't drive much so it will take a while, but I am going to do a few 10-90% charges to see if that improves things.
Sorta the Wild West out there, with these technicians it seems. I wish they'd just be educated consistently on what it really is, so owners wouldn't have to spend time getting at the truth. . . .
Assuming I've actually lost some capacity, which I probably have sitting at 6,500 miles driven, a 70% charge gives me right around 210 miles. I use around 35 miles a day for commute/errands. That leaves *plenty* for unexpected events. Not really sure I need to go to 90% for much more unexpectedness. If I can live with the more inaccurate range estimate, and still have plenty for unexpected emergencies, and I can eke out some more life/extended capacity on the battery long term, I'm not seeing any downsides to a consistent 70% charging regime.But there's no reason to. At 90% daily charge you have the extra range in case something unexpected happens, and more accurate reporting of range. And don't tell me how it's bad for the battery. Even if there's a statistically significant difference that can be measured in lab experiments, there's not been a meaningful difference in more than five years of use in the Model S.
I feel the same way since all my local drives usually are in the same range as what you describe. I still follow the advice of the tech I spoke with and so far I like the results. I quit charging daily to 70% on a scheduled charge but I still plug in at the end of the day so I can preheat the car on line power if needed or if I decide I need more range the next day I can start the charge from the app. When I plug in, I just stop the charge right away since I took it off a scheduled charge. When my range gets below 100 miles, I will start a charge after the 10pm TOU rate for that evening and let it charge back up to 70%. That shows a range of 216-217 miles just like it did when the car was new. I know the issue is software and I am fine with that but I do like to see the range display an extrapolated 310ish and it does consistently since I have been following that routine. I also started turning off my Bluetooth on my phone when I'm home since I think it was constantly waking or keeping the car somewhat awake while moving about my home as I could see it connect and disconnect depending where in the house I had the phone. I have got in the habit now of just turning it back on when I go out to the car to leave which isn't much different than remembering to grab the key fob of any other car since I don't use Bluetooth for any other device while I'm at home. So far so good.Assuming I've actually lost some capacity, which I probably have sitting at 6,500 miles driven, a 70% charge gives me right around 210 miles. I use around 35 miles a day for commute/errands. That leaves *plenty* for unexpected events. Not really sure I need to go to 90% for much more unexpectedness. If I can live with the more inaccurate range estimate, and still have plenty for unexpected emergencies, and I can eke out some more life/extended capacity on the battery long term, I'm not seeing any downsides to a consistent 70% charging regime.
Bottom line, when you start with 310 miles range, 70% SOC gives you plenty of "emergency" range. As I'm sure you know, a lot of the mid/lower battery capacity S's get around 250 brand new (see, eg, a 75), which after a year and 5% degradation brings that to 238-ish, which at 90% SOC is 215, give or take. The 60kw S's are of course even lower than this. So, at 70% SOC, my 3 has as much "emergency" range as a similarly aged mid/lower capacity Model S charged to 90%. I think I'm good at 70%.
Many service techs don't know as much about the car as you think they might-- almost as bad as the salespeople. Just because someone is trained to run diagnostics and replace defective parts doesn't mean he would necessarily know how the displayed range is calculated.Sorta the Wild West out there, with these technicians it seems. I wish they'd just be educated consistently on what it really is, so owners wouldn't have to spend time getting at the truth. . . .
Just got back from SC. They did a diagnostic check on the battery and indicated all was fine. The customer service guy indicated the technician's viewpoint was the lower implied range when charged was due to my driving habits and that if I drove more conservatively, my range would increase. I didn't argue with him, although everything points to this being inaccurate.
I'm going to continue charging to 90% to see if the imputed range improves.
No, because if you're not driving much it doesn't matter that your range estimate is a few miles off. If you're only driving 30 miles, what difference does it make if the battery meter goes from 250 to 220 miles or 245 to 215 miles range? There's no dispute that more frequent, smaller charges are better for the battery than fewer larger charges, and for people who are concerned about the battery that should take precedence over whether the algorithm for reporting range is as accurate as it could be. When you take a longer drive and need to charge more, then the algorithm accuracy will improve. Meanwhile, if you want the accuracy to improve, don't limit charge level to 70% as some are doing.
The Techs are not battery experts in the same way that chemical engineers are. If you want to know what Tesla's battery expert says, google "Jeff Dahn tesla Battery" tons of results..All these technicians can't be wrong about the battery...or are they all really that uninformed?
Interesting, can you point us to the statements that reflect this?Tesla's battery expert, Jeff Dahn, disagrees with your assertion that smaller, more frequent charges are better than fewer larger charges. He basically said that charging from 70 to 80 five times has the same wear effect as charging from 30 to 80 once. It is the number of cycles x energy that matters. In fact, he recommends keeping the battery at 70 SOC or less for maximum battery life.
Lots of info here: Jeff Dahn's recommendation on long term battery preservationInteresting, can you point us to the statements that reflect this?
Let me also add I am not suggesting DEEP discharge has no consequence. It does, But 80 down to 30 and then back to 80 is fine from what I have read, and is equal to 5 10Kwh discharges and recharges.Lots of info here: Jeff Dahn's recommendation on long term battery preservation
and here: Charging strategy for battery longevity
Generally googling "Jeff Dahn Tesla" yields tons of results.
Keep in mind, many of the comments are just posters opinion. Jeff says total charge amount is what matters, not number of cycles. I don't have the exact article handy, as there are so many of them.
