This is so true.I wish some of you guys would research degradation curves. Why does each generation of owners relearn the same stuff that is already common knowledge and established from copious data?
Clearly I need to keep my battery in the refrigerator when not in use.The cool thing is that battery stress is dependent on temp. In hotter temps, its more stressful, in lower temps, it's less stressful (at the upper bands).
So 90% in the winter is about as stressful as 60% in the summer, and that also means you can charge to higher SoC in winter to raise your usable range (since range is decreased with colder temps) without stressing the battery much more.
I guess you also need to factor in how hot the battery gets under load to get a complete picture, since it's not just idling the entire time.
This is not good!
What’s your lifetime Wh/mi average?I am going to add my data point
LR AWD
6000 miles
When new 100% charge: 305 miles
Now 100% charge: 265 miles
The degradation has been going down steadily since I received the car.
Tesla SC says that its normal.
I almost never charge to 100%. 90% daily
You’re energy usage looks like it averages about 300Wh/mi, which is way above rated usage at ~230Wh/mi. If Tesla is now tying the battery bar remaining miles meter to usage, then your “degradation” makes sense. There is a lot of circumstantial evidence around this forum that Tesla did something in the recent updates that changes how they calculate remaining mileage. The SC’s have also been claiming recently that the remaining mileage is dependent on driving behavior. The good news, if this is the case, is your battery is probably fine.Degredation seems to be slowing down a bit? Who knows.
View attachment 462981 View attachment 462983 View attachment 462984
You only have a fluctuation of 4 miles, and it's pretty much at new car range. I'd say you have a superman battery compared to most of us. Don't forget the range is only an estimation and not an exact science. Don't get wrapped up in worrying about it unless you see a 10% drop or more.What do you guys make of the attached pic? It’s not too bad for now but it seems to go down a little each day. Is it software updates or maybe something else? Thanks very much in advance.
Thanks. From my own experience, I had a significant drop in May after a software update. At the time, we were coming out of the winter months where my usage was high. Over the summer I have been getting much better than rated usage and have noticed roughly 10 miles added to the May 100% charge. I have a feeling many people are freaking out over their batteries for no reason. It would be good if Tesla explained how this number was calculated so people wouldn't worry about it. It would also quiet the crew on this forum whom firmly believe the calculation of remaining miles is done via a simple fixed multiplier and therefore any reduction of 100% is due to real degradation or a fault.I think you are onto something. I have no 'degradation' and my lifetime wh/mi is well under 230. You should keep asking this question.
