Model 3 Performance Spacers
Discussion in 'Model 3: Driving Dynamics' started by Cyclone1, Mar 9, 2020.
  1. Cyclone1
    Cyclone1 Member
    United Kingdom
    Hi,
    Looking at wheel spacer options for the Model 3 Performance. I’ve read through a few threads and find the information a little unclear.
    I understand there is a difference between which spacers can be fitted to the performance and LR/SR models. So if I were to order the ones supplied by Blox which are specific to the Performance model, then would they just bolt straight on?
    Also on the Blox website, when on the order page for the Spacers, does it refer the the individual spacer size or axle size increase? I would guess it’s the axle size, see link below;
    thanks
    BLOXSPORT 6061T6 5x114.3 64.1 for Tesla Model 3 perfermance [BLM Series] - $105.00 : BLOXsport Wheel Spacers, Aluminun 7075-T6 Forged!
  2. jmaddr
    jmaddr Member
    Florida
    Subbed. I am in this exact scenario myself and just posted on this in another thread (listed below). My research indicates the rotor on the TM3 with PUO (red calipers) is 5mm thinner than the non-P cars, leading to an extra 5mm of stud length on P cars when compare to non-P cars. This means the thinnest you can run is 20mm on the P, but you can run 15 on the non-P with the factory wheels before the factory studs make contact with the factory wheels when running a spacer. Personally, I think 20mm produces too much poke so trying to find ways to make this happen. I claim this as internet derived which is subject to the normal internet posting idiots so don't take this as truth.
    There is a great post of a brilliant looking P where I asked the builder exactly how he got 15mm to work on the front.
    Peanut Butter Jelly Time build - Tesla Owners Online
  3. vogz
    vogz Member
    Batavia, IL
    I am also curious about this. I also don’t want 20mm front. Too much poke.
  4. zrzrzrzr
    zrzrzrzr Member
    Texas
    He's on this forum as well. I emailed Bloxsport regarding 15mm spacers for a Performance, and they said the only issue is the bolt for the rotor needs to be removed.
    Building of the Faurrari
  5. T.F.S.
    T.F.S. Banned
    London
    Recently fitted a set 15/20 to the 2020 P3D, used blox and was very happy with them.
    high torque on the spacer to hub, lower torque on the wheel to spacer.
  6. Cyclone1
    Cyclone1 Member
    United Kingdom
    Thank you. When ordering from the Blox website did you select “30” size for the 15mm? There is no “15” to select on the webpage, so suspect it’s axle size increase they are referring to?
    Do you know if 15mm is the minimum size spacer that will fit on a Performance hub?
  7. T.F.S.
    T.F.S. Banned
    London
    Personally i used their number from the site and done it via whatsapp, i dont think less than 15mm will fit on front but really it looks fine, just under flush no poke at all, its how it should have came
  8. Cyclone1
    Cyclone1 Member
    United Kingdom
    Thanks
    if you look on the link in my first post, what option would you select to order 15mm spacers?
  9. T.F.S.
    T.F.S. Banned
    London
    I dont think the correct option is there.
    Whatsapp them on +8618898699536 they were very good and i done the whole order with them like that.
  10. Cyclone1
    Cyclone1 Member
    United Kingdom
    Appreciate that, I’ve just sent them a WhatsApp.
    How long did it take them to deliver? If you still have it can you sent me the part numbers?
  11. T.F.S.
    T.F.S. Banned
    London
    Couple of weeks. I don’t have the part numbers sorry
  12. JT_M3P
    JT_M3P Member
    Orange County, CA
    Are you on stock 20" performance wheels?
  13. T.F.S.
    T.F.S. Banned
    London
  14. Z P3D
    Z P3D Member
    Atlanta
    Word of caution, don't use 15mm on the fronts of the Performance+ unless you want the studs to damage the wheels. I've got first hand knowledge that without trimming, 15 will dig into the wheels with the BLOX. 20 in the back is just about perfect though!
    • Disagree x 1
  15. Z P3D
    Z P3D Member
    Atlanta
    With that said.... I've got a pair of slightly used 15mm BLOX if anyone's interested, PM me!
  16. Cyclone1
    Cyclone1 Member
    United Kingdom
    Have you got any pics to explain. Lots of owners have fitted 15mm with no problems. Maybe you used the wrong length studs or they were supplied incorrectly?
  17. mrbatwing
    mrbatwing Member
    #17 mrbatwing, Mar 21, 2020
    I understood it as the performance model has the thinner rotors and the stock wheels may not have enough internal space to accommodate the extra stud length that protrudes from the 15mm spacer. A 20mm spacer would cover that extra stud length.
    This is only an issue with the performance brakes and stock wheels. Lots of owners without performance brakes or who fit aftermarket wheels might not have the same issue with 15mm spacers up front.
  18. Cyclone1
    Cyclone1 Member
    United Kingdom
    Hi, reading the reply above about Blox 15mm spacers not fitting the M3P with 20’s, is making me doubt whether I’ve done the right thing buying them. Did you definitely fit Blox 15mm on the front with no issues?
  19. SuperNuprin
    SuperNuprin Member
    Seattle
    TLDR; 15mm spacers didn’t fit. So I only used the 20mm spacers in the rear. Front is stock.
    I had my car at the local tire shop today and I can confirm that the 15mm BloxSport spacers do NOT fit the factory 20” Wheels on the Model 3 Performance. The factory studs hit the back of the cavity of the OEM wheel.
    The factory studs protrude out 17mm from the 15mm spacer. And the cavity pockets of the OEM 20” wheels are only 14mm deep.
    I purchased the BloxSport 15/20 set back in January and waited for spring to get my factory summers back on. Glad I saw these post the past few days.
    I can also confirm the 20mm spacers fit the front. But 20mm makes the wheels poke out too much in the front for me, on the stock suspension.
    So I left the front stock and used the 20mm spacers on the rear as planned.
    Are there 10mm hub centric spacers without the studs. Anyone know where to get these?
    Yes, I know I can buy new wheels with the proper offsets. I really want the Vossen HF-2’s or the HRE P-200’s.
    But I have a budget and would rather get coilovers before a new set of new wheels.
  20. Cyclone1
    Cyclone1 Member
    United Kingdom
    Thank you for the clarity and sharing this. What Is annoying is that I messaged Blox and made it clear the car was an M3P with standard 20’s, yet they made a recommendation for me to order. Just been reading back through some other threads and looks like the other alternative is to fit 3mm spacers on the front.
    I’ll be contacting Blox to see what they say and if they’ll take the 15mm back.
    H&R do a 17mm version but it sounds like these will be 1mm short still.
