Model 3 Performance Spacers
Discussion in 'Model 3: Driving Dynamics' started by Cyclone1, Mar 9, 2020.
  1. Eddie1218
    Eddie1218 Member
    San Diego
    Following.
    Planning on ordering the H&R's but wasn't sure the width of the Ubers compared to the wheels from last year would need different sized spacers.
  2. aspec818
    aspec818 Member
    Bay Area
    #242 aspec818, Feb 6, 2021
    Have blox 5mm up front on a P3D and the 20” wheels are still a bit sunk in. Any 10-15mm front spacers work without shaving lugs? So much mixed answers everywhere. 4F091478-9038-4FD4-BFF2-7650B25FE7EF.jpeg
  3. ADAMBOMB
    ADAMBOMB Banned
    If your simply putting a 5mm hub centric spacer on your car and you have a p3d you will be fine. If you need any larger you will not have enough factory stud for the lug nut to be safely installed. I tried a 8mm spacer and is not really safe. Not enough stud.
    Due to the fact the p3d rotors are 5mm thinner than the other models you will need a minimum 20mm spacer with studs. Anything smaller may work depending on how deep the pockets are on your wheels. My personal experience is that the 15mm didn’t work and studs were hitting inside pocket as many others have experienced. If you want to shave or cut the studs you can but not the route I wanted to go.
    20mm is the sweet spot if you can deal w slight wheel poke. I used H&R. On the p3d the rotor has a lip on it and other brands say they work but physically don’t. The inside bore needs to be beveled out and most are just tapered. See pics. The silver one is the H&R and you can see how it’s supposed to look. 06EE6503-3891-482F-A20B-20190F4286BC.jpeg 7C5CD074-7EAF-438A-820C-C161F4EA5670.jpeg 55950997-8642-435A-A993-51329D263A49.jpeg 11FEC29F-2455-4E43-ABCF-FDDDE8664951.jpeg
  4. NXN-P3D
    NXN-P3D Member
    nothing wrong with shaving 1-2mm off the front studs. I did it and it was fine. Upgraded the wheels since then and that was fine too. 5 is negligible and 20 is too much poke for the fronts. I think H&R has 17mm hub centric spacer.
  5. wstamaria
    wstamaria Member
    Diamond Bar, CA
    What brand is the black spacer? I am trying to find a Blox/H&R alternative. Were those any cheaper? Im throwing some Aeros on my M3P for commuting duties and at this point don't feel like spending another 200+ bucks on spacers unless i really have to. (i have a BBK so i dont have to worry about the step in the hub)
    Thanks.
  6. ADAMBOMB
    ADAMBOMB Banned
    Tesla model 3 & Y 15mm/ 20mm staggard Ultra heavy duty wheel spacer kit | eBay
    Also if you have the pup p3d you cannot use the Aeros. The offset is not the issue w those it’s the fact the wheels are too small to clear the calipers. Some people have gotten it to work however have to save down an edge on the red caliper. Now other 18 inch wheels do work like the ones from tsportline.
  7. ADAMBOMB
    ADAMBOMB Banned
    You do have to worry about tha the step
    In the hub since your wheels may have the step if your installing a spacer then that’s what needs to meet the rotor. Not the wheel
  8. blaferty
    blaferty Member
    GA
    Anyone know if BloxSport/Bonoss lug nuts have changed other than color from silver to black?
    I installed larger of two styles (silver).
    Hard to remove lug nuts because socket does not
    make complete contact.
  9. wstamaria
    wstamaria Member
    Diamond Bar, CA
    My rotor hat is thicker than the step is tall therefore the area that meets the back pad of the wheel is flat.
  10. wstamaria
    wstamaria Member
    Diamond Bar, CA
    I have an aftermarket (Rotora) Front and rear BBK. 380x32 front, 350x29 Rear. The rears fit fine as is, but i am downsizing the fronts to 355mm to fit the Aero wheel.
  11. Blue247carz
    Blue247carz New Member
    Uk
    Hi guys, just picked up the 2021 M3P
    Purchased 5mm spacers for the front and 18mm spacers for rear. Had issues as wouldn’t fit over the hub so not flush to the face of the disc/rotor.
    I popped down to a local machine shop who chamfered the inner edge so they now fit perfectly.
    Front looks perfect with 5mm on new 20” Uber Turbine alloys but rears stick out too far, personally I think 10mm on rear would be perfect for rear but studs would require shortening or changing.
    Also after driving the car feels odd in comparison to without.
  12. ADAMBOMB
    ADAMBOMB Banned
    What do you mean the car feels odd?
  13. Eddie1218
    Eddie1218 Member
    San Diego
    #253 Eddie1218, Feb 10, 2021
    So you are saying the 21 M3P need different sized spacers than the 20?
    Wonder if the additional 1/2" of rim width of the ubers changed what spacers fit right.
  14. Bluesmobile
    Bluesmobile Member
    No. Regular old Bloxsport 15/20mm work fine on my 21 M3P.
  15. P3D-R
    P3D-R Member
    Fremont, California
    Oh that's great news. That's the last bit of information missing from that Aspira fitment chart. I don't think they had the pocket depth measurement for the uberturbines. You don't happen to know this measurement do you?
  16. Bluesmobile
    Bluesmobile Member
    No I did not measure the pocket depth. It is at least deep enough to accommodate the protrusion of the lug studs from a 15mm spacer. I will try to remember to measure them when I swap street pads back in.
  17. P3D-R
    P3D-R Member
    Fremont, California
    Awesome that will be helpful. Great to hear 15mm work on the ubers for a performance model caliper car.
  18. KyleM3
    KyleM3 Member
    PA
    I have a 2020 M3P with 14mm H&R up front. They required zero modification to the studs. Happy as hell with the result.
  19. P3D-R
    P3D-R Member
    Fremont, California
    I'm not doubting you but this doesn't add up with all the data I have pulled on my 2020 P3D with the factory 20" wheels. You have obviously pulled this off without issues or vibration so just gonna check some things. You have the red calipers right? Wheels just like mine as seen below?
    I found the P3D stud protrusion on factory rotors is 32mm. With that said a 14mm spacer will still have (32 - 14) = 18mm of stud protrusion. Since the 2020 P3D OEM wheel has a 16mm pocket depth then there's still a 2mm clearance issue and is why a 20mm is recommended. It's very interesting that yours is working out so I'm just trying to figure out how or why your car is different.
  20. MODEL+
    MODEL+ Vendor
    Portland, OR
    #260 MODEL+, Mar 5, 2021 at 8:38 AM
    I believe it's a different approach than a studded spacer. H&R is a regular 14mm spacer paired with shank nuts that dig further into the lug bore.
    This is a decent solution for spacing OEM wheel applications, as you don't have to worry about the hub pocket depth. However, you will be stuck using these nuts exclusively.
