Model 3 Power Liftgate?
rdwlf
83
99
Sydney
One advantage for first time installers is I think is it looks like there are a LOT less wires required to go up into the lift gate through that rubber tubing as opposed to v1 and also Hansshow's kit which is a bit bonus!
Sorry, there were a few spelling mistakes in that post. Can't work out how to edit the post anymore.
It was meant to say
One advantage for first time installers is I think it looks like there are a LOT less wires required to go up into the lift gate through that rubber tubing as opposed to v1 and also Hansshow's kit which is a big bonus!
rdwlf
83
99
Sydney
Finished v2 install. Went smoothly. The screen does flash from OPEN to OPENED when opening and closing.
But what does the screen show after it has finished opening? Does it still flash between open and opened? Is it the same on the app on your phone?
Also they claim it's extremely quiet now. It's hard if you didn't have the older one.
dhtguru
10
0
ORANGE PARK
On the car's screen. After flashing OPENED it goes back to and stays at OPEN.
In the app, it just shows the car's picture change to an open trunk. When i close it, I get the same standard "are you sure you want to open" warning message.
Can't speak to its quietness.
Pcoliver
17
Holly Springs NC
Holding up great. I think these grip the ball a little stronger than the
plastic ones, which is perfect. The paint on the ball is worn/flaked
of course, and there's friction. That makes the trunk opening now
a lot gentler and smoother. If you want to prevent failure to open in
cold weather, greasing the ball/socket is important. It's all metal on
metal now, I'm not sure what the perfect lubricant would be. It might
even be worth sanding those remaining paint flakes off the ball if
it ever sticks on you. I think @i1Tesla picked the right spring and
strut, it's actually quite gentle.
Fernand - All still well with your metal socket upgrade? For some reason I can’t seem to get over the thought that I’m installing a ticking time bomb. Was also wondering if the Abstract ocean trunk kit would take your mod or if anyone has used their kit with any luck?
Fernand
1,464
1,457
Northern california
@Pcoliver I'm not sure why it would be a hazard. You mean the metal ball socket popping off the ball? No way. The way the retaining pin clip works, it grips and blocks way better than the factory plastic one. As to using any strut with a standard plastic socket end, we know of one case where the owner's strut popped out, after months of frequent trunk opening. He put some serious wear on that plastic. A lot of people use the trunk mode with the plastic ball sockets without issues, but I figured I'd go all the way with the metal part.
I don't know the Abstract ocean trunk kit, but the metal ball socket replaces any standard plastic assembly.
As to any stress on the trunk, actually the alternate struts are only a little stronger than the original, rather on the weak side. The red spring in context is weak too. The evidence? If you don't open the Trunk for a few days and it's cold, it's too lazy to pop open. Same thing on the Frunk. So any worries about distorting the car somehow aren't realistic, as we're not dealing with big changes in forces.
Now, what I need to do is sand that ball to get rid of the leftover patches of paint, to get a very smooth metal ball. Then clean both ball and socket of paint debris, and re-lube. We'll see how that works. But no worries, mate, if you use the metal part that strut isn't going anywhere to hit anything.
MarcG
2,926
1,729
San Francisco
I likely won't find out until Oct/Nov when it starts raining around here again.. but that's a good point and I'd also like to know this from those who live in "wet" summer areas.
Sooo it finally started raining here, and sure enough, water drops found their way through the tail lights and into the trunk area.
I’m thinking this might be the reason why my control unit failed a few weeks ago, probably due to water ingress while I was washing the car.
Guess I’ll have to run the wires through the bumper now... not looking forward to doing the work, but with the rain forecast I think I should sooner rather than later.
GreenHokie
256
317
central Virginia
Hey Marc. Sorry to hear that.
I'm chiming in to provide another data point for anyone who will be installing this product and debating where to run the strut cables (through the tail light housing or behind the rear bumper).
I ran mine through the tail lights and have driven through lots of rains storms (some of which were very heavy) over the past month or so.
I have periodically removed the felt lining to check the area directly behind the tail lights, and have not noticed/seen any signs of water infiltration. I think using the suggested "drip loop" technique when running those cables greatly reduces or eliminates the potential for water to find its way into that tail light hole.
TomT
Technical Maven
Mar 24, 2014
427
354
NE Georgia
For what it is worth, I received the following email this morning:
We are doing big promotion for BLACK FRIDAY from 27th, Nov. to 2nd,Dec., all our products are selling in bottom price.
You can use our discount code "like tesla" to get 22.2% discount, then you will get our power frunk or trunk by USD389, including ship cost and taxes. It is the best best price for all over the year.
And we have adwards to the customer who share our links to their friends, family and they place orders sucessufully.
Promo activity purchase link:
Model 3 power frunk and trunk:
https://www.hautopart.com/product/tesla-model-3-electric-liftgate-and-front-trunk/
Model S(2016+) power frunk:
https://www.hautopart.com/product/tesla-model-s-power-frunk/
Model X power frunk:
https://www.hautopart.com/product/tesla-model-x-frunk/
If your friends make the order, please remember to send us your friend's order number and name to our email address [email protected].
Rewards information as below:
Get 1 order:1 set Welcome Door Light with customizing your name with 4 doors;
Get 2 orders: 2 sets Carbon Fiber rearview mirror cover;
Get 3 orders: 2 sets seat Massage Module;
Get 4 orders: 1 set Carbon Fiber Spoiler Wing;
Get 5 orders: 1 set Handle Sensor with 4 doors;
Get over 6 orders: 1 set Power Frunk or Trunk;
Get over 10 orders: 1 set Soft-Close Door with 4 doors.
What's more, we are looking for installer, if you can help other friends to do the installtion (they will pay you for the installation) or you have a recommend installer.
Please contact me with their email address, phone number and address, after confirmed, we will send you 1 set Welcome Door Light with customizing your name with 4 doors for free.
Thanks & Regards,
Dela Qin
Sales Manager
Cell: +86 156 2220 3621(WhatsApp,Wechat,Skype)
Email: [email protected]
Guangzhou Hansshow Technology Co., Ltd
MarcG
2,926
1,729
San Francisco
Glad it's working out well for you. I did install the wires under the tail lights in such a way that they come up from underneath the holes, however my suspicion is that the thickness of the wires caused the tail lights' rubber gaskets not to sit flush enough, so water still could drip in.
Anyway, I spent some time rerouting the wires through the bumper, and it turned out not to be that much of a pain. I found a way to pass the wires through the holes just under the tail lights and around to the side of the rear bumper using a wire fisher, and I only needed to unscrew the two 10mm bolts that are just under the tail lights, and the torx screws by the wheel well. See photos below for details.
One thing I made sure when re-installing the tail lights was to make sure the wires were out of the way completely, so that the gaskets could do their job properly when the tail light screws were tightened up. There was still play in the wire when I did that, just made sure to give them more space by pulling the weather stripping away a bit per the last photo.
I'll keep everyone posted over the next week or two if this was successful in completely avoiding water ingress.
rdwlf
83
99
Sydney
So finally prepared and installed yesterday. Took most of the day as I like to take my time and make sure everything is lined up and avoid damage. Thanks to all the videos and tips from everyone on this thread. Super helpful.
Works pretty good so far expect when opening the trunk, it opens with almost a violent jerk and then slows down. I am afraid if someone is too close to the trunk would get scared :)
Anyone else encountered the trunk opening like this?
Thanks!
Hi @km100 did you work out how to fix the aggressive initial open on the trunk? I finally got around to installing mine today and it is seriously scary how fast it opens initially before it slows down to the normal speed.
nealz
New Member
Nov 28, 2019
ARMONK
I installed the Teslaoffer power trunk, and it works well. However, I cannot get the foot sensor to work. I have gone over the installation with Raymond Wu (including sending pics of my wire hookups), and eventually he sent me a new sensor. Still won't work.
When I short the two pins on the connector the trunk opens and closes, but when I connect it to the sensor it doesn't work.
Any ideas about this would be appreciated.
Skione65
1,453
716
Kentucky
Let me know what you come up with...I have installed the foot sensor in the bumper.....but haven’t “spliced” the wires up and connected yet. LOVING The Frunk and Trunk kits though!
Ski
zero610
56
7
Texas
On the Hansshow v2 kit, do the trunk lights stay on when the trunk is open or do they flash?
Cintoman
233
256
Cumberland, RI
So I'm still on the fence as to whether I should go ahead and get the power frunk and the power trunk with foot sensor. I would be getting both or neither. But also debating on whether to get the Hansshow ones or the Teslaoffer ones. In the above post, Hansshow has a pretty good deal where if you get both, it would be $816.90 with the above coupon code ( a decent discount from the regular $1,050.00 price). I went onto Teslaoffer and getting the same thing would bring the price to $878.00. I am not aware of any Black Friday coupon code for Teslaoffer.
My understanding is that the front trunk for both companies are the same product. However, my understanding for the rear trunks are a little different. IIRC, with the Teslaoffer one, you'd have to connect to the CAN, which, if Tesla updates the CAN, you might run into some issues with the trunk powered operation. But Teslaoffer provides quick updates and then you're good to go. Whereas the Hansshow one you don't have to connect to the CAN.
I think further differences in the trunk for each company's products included that the Hansshow one you can open and close the trunk from the Main Screen inside the car, but the Teslaoffer one you can't. I also thought that the Hansshow one wouldn't show you whether the trunk was open or closed in the app. I don't know if there's any other differences in less wires, thinner wires, and non-connected connection clips (to make it easier to fit thru the trunk rubber tube).
Looking at the Teslaoffer one, on their site, it mentioned a few "exclusive" features, including the following:
  • Open and Close the tailgate using the touch screen
  • Preserve trunk status and alert (Exclusive!)
  • Silent trunk opening (Exclusive!)
  • OEM trunk rubber protection with silicon casing structs (Exclusive!)
Not sure if the Hansshow one has the above exclusive features or not? I've also heard that they are the exact same product, just sold by 2 different companies
Personally, I'd prefer to have it as OEM as possible within the app and the main screen UI. I'd prefer that the car showed me if the trunk was open or closed versus not having any idea if it was open or closed.
So I'm not sure what everyone would suggest to be the best option out there? My other thought is that I might not install this until the spring...even though I do have a garage attached to my house, it still gets quite cold in there during the New England winter. Despite a decent deal with the Hansshow Black Friday coupon code, and the sale that Teslaoffer is having with no coupon code (is there a coupon code out there for Black Friday??), I'm wondering if I should just hold out until the Spring, when there might be a Version 3.0 or 4.0 of these products for probably about the same price.
Thoughts?
Thanks,
--Cintoman
alexsu
16
2
Los Angeles, CA
Not for a Grand+!!! Or whatever they want.
Ski
Right now they have special - $750 all 4 doors.
BTW: I feel stupid - got the trunk yesterday - ordered 4 days ago. Started installation and went to their website for video to find out that now the special price is $200 less than I payed... Trying to get the difference back. Do they answer WhatsApp on their business hours?
