Also something I tend to do when traveling in cold weather, is I crank the heat up when supercharging. This way I get everything in the car nice and toasty before I unplug and have some "stored heat" in the car and in my body.
Yes, all that. A few more suggestions --I wouldn’t say worry about, just use best practices— Start with 100% charge. Always preferentially use the seat heater in winter and set heat temp down to what you’re comfortable with when having seat heater on. That’s what it’s there for. Plug in at your parents house, even if’s only 120V. If you find yourself using more range than you expect, just slow down by 5 mph.
My scheduled delivery is 12/14 for a MR RWD. That same weekend, I have a trip planned to visit my parents which is a 200 mile round trip, temperatures in Pennsylvania are typically around 32 or slightly lower at this time of the year.
A majority of the driving is going to be highway at 70-75 mph. Do I need to worry that by using the heated seats and heater that I will not make it back home? Crazy to think that I just bought a car that I'm worried won't make that trip in the winter.
Although remember it's a round trip -- if there's a headwind one way, with some luck there'll be a tailwind the other way.If there's a head wind
You won't make it unless you charge or drive slowly and keep the heat off. If there's a head wind or precipitation, you're going to experience some serious range anxiety. Can you plug in at your destination?
I recommend planning on a 15-20 minute stop at a Supercharger so that you can both travel at reasonable highway speeds and be comfortable. Make sure the stop is at least an hour after you've started driving (either there or on the way back) so that the battery is warm enough to charge at full speed. If possible, it's best to arrive at the Supercharger with a warm battery between 15 and 20% (actually about 13%, but that's cutting it a little close for a new EV driver). Definitely plot the trip out on A Better Routeplanner and be sure to chose the correct settings, including more settings.
Enjoy the trip! We're taking our LR AWD on a 1,700 mile adventure to Michigan this weekend. Fortunately there is no real precipitation in the forecast, but the temperatures will be in the 20s.
Wait, really? I think 200 miles r/t will be a smidge tight but at 100% charge eminently doable. I did 200 miles +/- 20 miles in the Midatlantic and Northeast three times during Thanksgiving, and every time I started with 85% or so charge and stopped at a Supercharger before I dropped below about 7%. I also found the "Charge Remaining" estimator to be highly accurate within about 10-15 minutes of getting on the road.
I don't disagree with stopping at a Supercharger, I'm just a little surprised since I didn't see any issues re: cold battery or limited regen in the original post.
Mid-December can be a lot colder than Thanksgiving. Weather can also be more of a factor, particularly in the Pennsylvania mountains. It's doable on a single charge if conditions are favorable, but I think his trip will be more enjoyable if he plans a short charging stop.
Yeah, I'm not really disagreeing with you, it's good advice. I think part of my post was my own vague concern about changing weather conditions up here in MA. We did the TG drive around 37-45 degree weather. Winter has hit hard now though and I'm really hoping we don't see performance plummet at 20-30 degrees. We have a 175 mile drive for Xmas to see some very skeptical-about-EV relatives (one of whom owned an S and hated it!), and if we're late because of a supercharger stop we'll never hear the end of it!
Also something I tend to do when traveling in cold weather, is I crank the heat up when supercharging. This way I get everything in the car nice and toasty before I unplug and have some "stored heat" in the car and in my body.![]()
I think it’s not so much “pretty much” as it is exactly the same charge rate, at least as soon as the charge starts to taper in the slightest.Absolutely agree but just wanted people to know they can crank it while plugged in to a SC and still pretty much get the same charge rate.
Drove from southwest Chicago suburbs to St. Louis over Thanksgiving weekend. Left with battery at 99%, heat set to 70, seats on low, air temperature at 40. Got to Springfield, IL, with 19% left, outside temp 65. Coming back was harder. Was unaware of limited charging at "cold" temps (mid 20s in STL) and could only get 12-15Kw out of St. Charles supercharger. Had to stop in Springfield again and Bloomington to make it back home.
During 'warm" weather I get 230-240 Wh/mi. On the way back the reading was around 310-330 Wh/mi (with same in-car settings but much air temps in the 20s.) One good note is that the energy consumption/projection graph on the new (V9) energy app (for trip) was pretty good at estimating energy consumption and final battery reading at each supercharger.
