227, which is 74.5kWh/325 miles = 229.2Wh/miles to be exact.. Some people use 74kWh, hence the 227.
Sure, it isn’t a “meaningful” mile as far as an actual distance that can be traveled, but the EPA number is still just a number that divides the energy in the battery into that many equally sized chunks of energy (as suggested by your first formula, though that formula should use the recharge event energy, not the energy in the battery).
So if you take the 89kWh from the recharge event (I think that is what it was In the document...maybe it was 87kWh...don’t have document in front of me right now):
89kWh/310 rated miles = 28.7kWh/100mi
This is very close to the AWD 29kWh/100mi (rounded) rating.
And I was just pointing out that my recharge event today seemed to be a bit more efficient than that, when referenced to the number of chunks of energy (90) that I added to the battery - and I am not sure why there was such a large discrepancy. It’s off by about 10%. Part of this may be due to the charging method used (perhaps more efficient than what was used in the EPA test but 6kW seems unlikely to be better...), and the rest could be due to actual reduction in total battery capacity - perhaps my full recharge event (to 304 rated miles) would only be something like 89kWh*304/310*0.9 = 78.5kWh, which if it is not due to charging efficiency improvements, would suggest that my battery simply has lost 10% capacity (not the 2% suggested by the rated miles reduction).
But no idea - I’d need to go back and review charging data from last year (I can) to compare - an event on 12/18/18 when the car was a month old shows 33.78 kWh from ChargePoint to add 126.5 rated miles, according to Stats. That is 26.7 kWh/100 miles (which is 2.7% higher than 26kWh/100mi...which is interesting that it is different). Still not 29kWh/100mi though. Not sure how accurate the ChargePoint meters are (there is no charge for using them).
Part of the difference may be due to the reserve buffer, of course. That is energy below zero rated miles which would have to be replenished in the recharge event - if it was used. But people keep experiencing this energy as not being available (car dies pretty soon after getting to 0, or even before - though it may be due to people demanding too many kW at that charge level). So if that (buffer energy not available) is the case, that energy would not have been available in the EPA test, unless the final depleting cycle is done at a very low steady discharge rate (it might be). So not sure the buffer can explain the discrepancy either.
