Model 3 Rebuilt Title - Supercharging Removal
Discussion in 'Model 3: Battery & Charging' started by Sadus671, Mar 30, 2020.
  1. BritneySpears
    BritneySpears Member
    San Jose, California
    Received today. Will post a review soon.
  2. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    What firmware version is on your Model 3?
    Hopefully you have better luck than this person:
    He is on the most recent "holiday" update. (2020.48.26)
  3. BritneySpears
    My luck was a little better. Went to an EVgo station (1) and neither chademo or setec ccs worked. Went to EVgo (2) and plugged in chademo, wouldn’t work, called EVgo, spent some time plugging and unplugging then it worked at 25 to 27 kw. Car was already charged to 70%. About a month ago I got 40 kw on chademo with a lower charge state.
    drove to an electrify America charge station and plugged in ccs adapter. Wouldn’t work. Called for help, advised to to try adjacent station, plugged, unplugged, repeat, finally got it charging but only at 25 kw. The station was capable of 150. Note: this particular electrify America station charged $0.40 / kWh. Horrible. That’s equivalent to 30mpg ice car at $3 per gallon roughly.
    I have the latest holiday software.
    Will try further when soc is down to 20% or so.
    If tesla throttled my 3rd party charging ability I’m burning down the building.
    • Informative x 3
    • Funny x 2
  4. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    #244 cwerdna, Dec 28, 2020
    Before going to any non-Tesla public charging, it's best to check its rating and for recent check-ins on Plugshare. Not sure if you're willing to post the addresses or Plugshare URLs of the problem stations.
    Last time I went to PlugShare - Find Electric Vehicle Charging Locations Near You, both DC FCs were broken. (And yes, I checked in.)
    So you actually got the Setec CCS adapter to work?
    ALL Pricing and Plans for EV Charging | Electrify America stations in CA are 43 cents/kWh for Pass (and guest) members and 31 cents/kWh for Pass+ (which is $4/mo).
    (Oops, part of this is a repeat. I've told you about DTA before.)
    Since you list your location as San Jose, you can get free or discounted charging via Home Page - DRIVEtheARC at a limited subset of EVGo chargers (ONLY the ones spelled out on their site or as DTA sites in their app). The aforementioned Walmart in Milpitas site is one of them. You need to go thru sections 4 (just once) and 5 of How to Use the DRIVEtheARC App - DRIVEtheARC.
    I've gotten a ton of free CCS juice (and a bit of discounted juice) from DrivetheARC w/my Bolt.
    ChargePoint HQ 41 (at their headquarters) at 254 E Hacienda Ave, Campbell, CA is dual-standard DC FC currently set to free and has been like that for at least a few weeks. It's still showing as free at ChargePoint. I personally used it to pull down over 27 kWh of free juice on Dec 18th.
    In the past, it's price has varied from free to cheap to ok (I think 25 cents/kWh) to free.
    PlugShare - Find Electric Vehicle Charging Locations Near You is 19 cents/kWh for CCS, CHAdeMO and L2. I've personally used CCS and L2 there.
  5. BritneySpears
    Great info for local, South Bay Ca people. I work near San Jose so I'm very familiar with those areas. I have all those apps but haven't utilized them. I WFH (work from home) and I rarely travel far enough away to need to charge but this is all a necessary exercise for when life gets back to more normal.
    Yes, I got the SETEC adapter to work but it's strange it only charged at a 25kw rate when I was at 70% SOC. I had Elec America on the phone at the time and the technician expected it to be higher as well since the capacity of the machine was 150 kw. I didn't record my procedure very accurately as I plan to do that better when I go to juice again at a lower SOC (state of charge). More info to come then.
  6. Webeevdrivers
    Webeevdrivers Active Member
    Canada
    Well, at least it worked. Keep us posted. And thanks.
  7. cwerdna
    SF Bay Area, CA
    Awesome that it worked at all. You're not going to be able to get anywhere near 150 kW.
    Since the Setec adapter is allegedly limited to 200 amps, let's say the voltage is 370 volts. 370 volts * 200 amps = 74,000 watts = 74 kW. Model 3 drivers (since I don't have one) can fill in what the proper voltage ranges would be.
  8. Boeingpilot
    Boeingpilot Member
    Central PA
    At least you got it working! On my MS 90D, no luck. Got either communication error or Failed isolation test. This was on a Blink charger (built by btcamerica)
  9. BritneySpears
    Yeah, I get those two errors with the tesla chademo adapter on an Evgo station frequently. Half the time when using chademo I call Evgo and they fiddle around with some things, reset the machine, and then it works. The Setec CCS on Elec Amer behaved similarly and finally worked after a few unplugs, replugs. I wonder if this is a firmware issue with the stations that aren't up on how Tesla communicate. Or maybe the comm issue is on the Tesla side?
  10. Boeingpilot
    Boeingpilot Member
    Central PA
  11. Boeingpilot
    Boeingpilot Member
    Central PA
  12. Bnelms25
    Bnelms25 New Member
    Richmond VA
    Who is the hacker?
  13. Knightshade
    Knightshade Well-Known Member
    NC
    Jason Hughes
    Services | 057 Technology
    (or he did anyway, dunno if he still does since the "we can sue you if you do this" language was added)
  14. Kostik
    Kostik New Member
    Ukrainian
    Hello friends ! I have the same problem, I bought a refurbished car and fast charging is also turned off, but that's not all, in August they stopped updating my car. I wrote many times to the service and I get the same answer your machine is not supported. Maybe we will create a petition somewhere and sign and send it to Tesla. sorry for my english i am writing through a translator i am from ukraine we have almost all cars rebuilt
  15. rrolsbe
    rrolsbe Member
    Albuquerque
    This might have been mentioned somewhere in this long thread. If so, sorry for the redundancy.
    There are cases where cars are totaled for things like hail damage among other scenarios where there would probably be no damage to the HV/charging components of the car. I believe salvage titles are issued anytime insurance companies right off the car as totaled? Does Tesla disables DC fast charging on a hail damaged car?
  16. MP3Mike
    Oregon
    Yes. They have no way to know why a car was totaled, they can just see in the national database that it was.
