Model 3 - seperate regen brake lights?
Discussion in 'Model 3' started by Candleflame, Jul 10, 2017.
Tags:
  1. Candleflame
    Candleflame Member
    QLD, Australia
    Dont know if anyone else noticed this:
    The brake light is made of 2 components, the interior light and the exterior ring. at 0:17 he slows down and only the small brakelight comes on, followed by the bigger ring one when he presumably comes to a harsh stop using the brake. Later at 0:29 you can see how again he slows down GENTLY this time and only the small brake light comes on.
    Could the regen trigger the smaller brake lights? And if so... On the Model S the brake lights only come on if significant regen is applied (i.e. not the one applied to a car moving at perhaps 3mph)
  2. eSpiritIV
    eSpiritIV Member
    Portland, OR
    I bet your correct
  3. WileyTheMan
    WileyTheMan Peanut Gallery Member
    Los Gatos, CA
    Good catch.
  4. tracksyde
    tracksyde Member
    So Cal
    This was covered in one of the other threads, but when the taillight comes on, you can see the headlights came on too (reflection in the Model X in-front of the 3).. so he probably hit the headlights on accident.. some how
    Here it is: When will we see a photo of SN1?
  5. Bokonon
    Bokonon Title-customizing Member
    Newton, MA
    He turned on the headlights for a second -- you can see the reflection in the Model X opposite of the 3.
  6. Candleflame
    Candleflame Member
    QLD, Australia
    dang.... no matter how sherlock you are, someone will outsherlock you.
    • Funny x 2
