Model 3 "sleeping" dimensions
Discussion in 'Model 3: Interior & Exterior' started by JoeCoolMan24, Jun 13, 2018.
  1. JoeCoolMan24
    JoeCoolMan24 Member
    Northwest Indiana
    I've done a google search and a search on this forum and I can't seem to find dimensions for the length and width of what would be the "sleeping quarters" for anyone camping out in their car. Back seats folded down, front seats moved up all the way.
    Costco currently had a thin air mattress marked down to $25 that I thought about purchasing to use for sleeping in the back of the Model 3, but I have no idea if it will fit. They also have a thin foam sleeping "pad" for $20 that is much narrower, but I still don't have any idea on the length available.
    My suspicion is that it's not big enough for the air mattress, which is something like 76" by 56", but I would still like to know so I can look elsewhere online.
    Thanks!
  2. bnsfengineer
    bnsfengineer Member
    So.Ca.
    Don't quite understand why you don't just go out to your car and measure it? Also you can never go wrong purchasing from Costco since they will just take it back.
  3. MissyMcBee
    MissyMcBee Member
    Silicon Valley
    Do a Tesla Model 3 Amazon search and you may find an airbed that was formulated for the car... (don't know if it is still there but i've seen it)
  4. JoeCoolMan24
    JoeCoolMan24 Member
    Northwest Indiana
    Because I don't have a Model 3 yet??
  5. JoeCoolMan24
    JoeCoolMan24 Member
    Northwest Indiana
    That's a good idea, If I could find one made to fit the exact dimensions, I can just use those dimensions to compare against the ones at Costco. I'll go see what that yields.
  6. goto10
    goto10 Member
    Provo, UT
    I don't have the dimensions handy but I did spend a night sleeping in the back. I'm 6' tall and found I had to sleep a little bit diagonally to fully stretch out. If I adjusted the seats all the way forward it might just be possible to get a 76" mattress in there.
  7. bnsfengineer
    bnsfengineer Member
    So.Ca.
    LOL Ok when I get home I will measure it for you.
  8. Kenriko
    Kenriko Vendor
    Bay Area, Austin, Miami
    It's a Twin Mattress that'll fit, same as the Model S. If you get a Twin XL (80in long) then it'll go right up to the back of the front seats and you'll want to get inflatable footrests to support the end of the mattress.
    There are folding memory foam mattress from Milard on Amazon that works well don't go thicker than 4in though since the trunk opening is not as tall as the Model S.
  9. JoeCoolMan24
    JoeCoolMan24 Member
    Northwest Indiana
    From reading online it seems that the width to the narrowest spot is about 38". And then length range is like 72"+. A bit narrower than I would have thought, but oh well.
  10. Paik4Life
    Paik4Life Member
    Virginia/DC
  11. Pkmmte
    Pkmmte Le meow
    Los Angeles, California
    • Funny x 2
  12. bnsfengineer
    bnsfengineer Member
    So.Ca.
    HaHaHaHa.... 67x37 thats at the most narrow point... I would get a hotel room or sleep in a tent.... That's the first time since I owned putting the seats down... its too small but if you had no choice I guess you could do it!
  13. bnsfengineer
    bnsfengineer Member
    So.Ca.
    Its actually a little smaller... I measured at the end of seats to the rear... Ohh maybe that measurement is with the headrest which I did not measure from.
  14. bnsfengineer
    bnsfengineer Member
    So.Ca.
    The length would probably be ok but the width is way too big unless it would fold up on the sides when you laid down on it.. almost extra 10" on each side.
  15. Paik4Life
    Paik4Life Member
    Virginia/DC
    Yeah, I think they include the extra space that they have a support piece for, not just to the end of the seats (practical space unless you have some other support of your own).
    ~Paik
  16. Jwlindy
    Jwlindy New Member
    Waukesha, WI
    I would suggest a Therm-A-Rest or similar sleeping pad made for tent camping. It would easily fit in the model 3 width-wise. With the vertical restriction of the trunk I don't think you'd want to go too thick. I imagine with a nice sleeping bag, a small pillow and a Therm-A-Rest you'd be quite comfortable
