Let me preface this by saying the Model 3 is a great car and I love it...on most days. That being said, I was quite frustrated last night after I had a day of snow during the morning, followed by melting temperatures, followed by a very cold evening. I had to move the car off the street and into my driveway but everything on the car was frozen! There was not too much visible ice on the car, but the door handle, windows, and charge port were frozen shut. Upon being unable to get inside, I turned the heating on in the car with the app to defrost it. 30 min later, still frozen! I finally managed to get the door handle to budge with some banging around but as a result the door came open while the window was still frozen. Now I couldn't close the door in -15C (5F) weather! I did my best to close the door as much as I could and cranked the heat to full blast to try and thaw the window. While waiting I found a suggestion of someone recommending to use a credit card between the window and bottom seal to separate it from the ice. I did that and definitely felt a lot of ice inside the door under the seal that was keeping the window frozen. Unfortunately this did not immediately resolve the issue, the window still would not go down. After 20 more minutes of defrosting the window finally came loose and I was able to close the door. Good, now I can go home and relax right? WRONG! Tried to plug the car in to charge, since nearly 1hr of full blast heat almost killed the little charge I had left, but the charge port would not come open due to freezing. I pried it open, but there was ice inside of the charge port prohibiting me from inserting the charger! 10 min later of trying to chip and clear the ice away with a screw driver it finally went in and started charging.
This car preforms great in above freezing temps, but WOW what a frustrating experience. Anyone else experiencing this? I was expecting having occasional issues with this that could be resolved by 10min of preheating since I knew this was a frameless design, but not to this extent! Seems the Model 3 could use some better weather sealing, or stronger window actuators.
