Model 3 Software Update 2019.5.x
Discussion in 'Model 3' started by PoitNarf, Feb 14, 2019.
  1. ModelNforNerd
    ModelNforNerd Active Member
    Ayer, MA
    Some of us in New England are in houses that are old enough to have been around since EVs were popular the first time.
    So, in my case, that actually means I have NO garage, sadly. Some of my neighbors have attached "carriage houses" that are too small to hold a modern car in them. It was a design choice for the times.
  2. dmurphy
    dmurphy Woof.
    New Jersey - Morris County
    Our home was built in ‘68. Along the way, a previous owner carved out a sun porch from the rear corner of the garage - leaving it no longer deep enough to fit a vehicle. Width is fine, but if I were to park a Model 3 in there, the garage door would have less than 1/2” clearance if I parked the nose against the wall.
    Honestly, I’d rather have the sun porch and the car in the driveway. It’s all good.
  3. TT97
    TT97 Active Member
    Los Angeles
    I think there was a disclaimer about the age of the house. My parents house was built in the early 15th century and has a half mile driveway that can't fit anything wider than a Piaggio Ape (and a scary drive with something that wide) so they need to park in a lot by the street. It's hard to blame the architect for not having the foresight for vehicles 600 years later.
  4. geometro
    geometro Member
    Austin
    I received 2019.5.15 about two weeks ago, but my 100% is at 307 miles (LR). Shouldn’t it be closer to 325 miles?
  5. Swampgator
    Swampgator Active Member
    Florida
    If your garage door opening is smaller than 83" it is a very small door. A Ford fusion won't fit either. That is a lawnmower access door at that point and totally unsuitable for automobiles.
  6. pkwu06
    pkwu06 Member
    Georgia
    The highset I have seen on my 3 is 315 miles
  7. M109Rider
    M109Rider Active Member
    Kitchener, Ontario
    Likely depends on your calibration.
    Doesn’t mean the car has degraded. Most likely means the calibration is off a bit. Nothing to worry about.
  8. jcal0820
    jcal0820 ride the wave
    southern California
    When I received my update, had about 263 miles of range... once the software update completed, I saw the range increase to 273 miles, even though it wasn’t on the charger at the time. Anyone else experience the same?
  9. JulienW
    JulienW Active Member
    Atlanta
    #1149 JulienW, Apr 27, 2019
    Why isn't there a Sticky thread that list the software updates in order with the notes (maybe the same thread across all Model forums)? Also how to read? 2019 is the year? Is the next number version and then minor/build?
  10. wcorey
    wcorey Active Member
    Killingly, CT
    Year-week(1-52)-build
  11. TEG
    TEG Teslafanatic
    Try this:
    Model 3 firmware features table
  12. JulienW
    Atlanta
    #1152 JulienW, Apr 27, 2019
    WOW, looks like I get things done (or get others to do) just by complaining.:eek::D
    EDIT: Also is the the public release builds? In other words when my 3 gets here I want 2019.12.1 d9eaf40 (unless we get another build release)?
  13. TEG
    TEG Teslafanatic
    I think they plan to update the table to show any builds that were EAP ("Early Access Program") beta releases only. Like 2019.9 maybe.
    Personally, I still have 2019.8.5, and look forward to 2019.12.x
    They push out the updates in batches, so many people stay on older releases for a while.
  14. wcorey
    Killingly, CT
    #1154 wcorey, Apr 27, 2019
    No, you get what you get. It'll be a public release as opposed to EAP. We don't get betas....as a general rule. Those are special case where you have to be invited.
    When I picked up mine last year, I happened to get it with the, then current public, release. But it easily could have come with a prior release. However, make sure you have a really solid wifi access in your garage or where ever you plan to 'garage' it. With that you'll automatically get downloads and notification on your smartphone allowing you to chose when you apply it (push it to your car). It may be frustrating at times as people might be talking about a release you don't have and may not get for a week or more.
