About 450 kg or 1000 lb for M3 according to a post by an owner on another forum (don't remember the exact figure). Good first post.Hi everybody,
My 1st post
One question - what is maximum allowed load in lbs or kg (passengers + luggage) in model 3?
Hope that it is more than 400 kg.... How about Model S and X?
Hi everybody,
My 1st post
Load Capacity Labeling
It is important to understand how much weight your Model 3 can safely carry. This weight is called the vehicle capacity weight and includes the weight of all occupants, cargo and any additional equipment added to your Model 3 since it was manufactured.
Two labels attached to the center door pillar indicate how much weight Model 3 can safely carry. Labels are visible when the front door is open.
Warning: Overloading Model 3 has an adverse effect on braking and handling, which can compromise your safety or cause damage.
Note: Never load more than 55 lbs (25 kg) in the front trunk. Doing so can cause damage.
Caution: Never store large amounts of liquid in Model 3. A significant spill can cause electrical components to malfunction.
Just as a point of reference, many 5-passenger cars have a load capacity of 850lbs, so the 3 is already doing nicely if it is anything greater than that. Google tells me that 850 lbs is the rating for the Honda Accord, Ford Fusion, and Mazda 6.
I was surprised one day when I noted that my own very small 2008 Honda Fit had a sticker on the door jamb indicating load capacity of 850 lbs, while a relative's newer (2015?) and much larger Honda Accord had a sticker indicating an identical capacity at 850 lbs. I realized that while larger cars may give you more space, it might only be additional space to wiggle around, not carry more stuff.
I also had a 2003 Ford Escape at the time. A small SUV, but an SUV nonetheless. Dwarfed my Honda Fit. Max load on the sticker was 899 lbs...so even going to a more truck-ish vehicle didn't gain much in load capacity.
I currently have an 8-passenger Honda Odyssey van, and IIRC, the load sticker on that indicates something like 1200-1300lbs.
The average US woman is now ~160lbs and the average man is ~190lbs, so it is obvious that cars are not designed even to hold an average adult in every seat, much less include cargo on top of that.
That being said...carrying kids in the back seats is more common than a car full of squished/uncomfortable adults, so it seems to work out...
Are u calling us fat?
Oh of course not! As a population, we have just evolved to be more big boned it would seem .
On another note:
Model 3 official ratings are up on fueleconomy.gov. Interestingly, if you compare it to the Model S and hit the "specs" tab, you can see that the Passenger Volume on the 3 is listed as 97 cubic feet, while the S only specs out at 94 cubic feet.
Hopefully this link works:
Compare Side-by-Side
I had previously devised a model that takes into account weight, rolling resistance, aerodynamic drag, and the characteristics of electric motors (flat torque until power limit, then flat power, then a slight taper as efficiency drops with high RPM). The major unknowns were what speed the vehicle switches from torque to power limited (presumably battery current limited) and the peak torque (deliverable - grip limited).
With motor-trend's published performance numbers, I was able to fill in those unknowns and generate curves that match their data. That in itself is not especially interesting, but if that data is used to extrapolate performance for the DLR, standard range, and DSR, I thought others would be interested.
This assumes that the power is limited by the battery (so the SR has about 67% the power) and that torque is limited by grip (so the Ds can generate twice the torque until power limited). I assumed a flat 50kg (110 lbs) for the 2nd motor. I find it interesting that the SR 0-60 comes in pretty close to the "official" numbers, and the DLR numbers are pretty close to what we've seen from test mule video footage. These both give me enough confidence to post my numbers. I don't have any real speculation on the performance model performance since I'd assume it would be using a battery pack capable of higher output power, but by how much is completely unknown. Please don't read too much into the # of significant digits, there are way too many variables to actually be that precise.
I couldn't figure out how to post on a grid (spreadsheet style) so it's an image, sorry...
The Dual motor cars do not double the Torque output ... for reference see the Model S and X specs
I am afraid your logic may be flawed ... Tesla uses a small and large motor on all Dual motor cars and does not multiply torque by 2XWell, there are no single motor X to compare, and with the S there is a different gearing ratio between front and rear as well as different motors used in the rear between models (the 85 has a big rear motor and an 85D has similar sizes front and rear both smaller than the rear drive only motor).
I'm making the assumption that they are actually using the same motor for both axles since it seems they're using that motor everywhere going forward, also there's less incentive to have a different gear ratio as well since the PMAC has a flatter efficiency curve than induction and the 3 has a lower top speed....
There's pretty much no way to get the performance numbers the tested 3s put out without them being traction/torque limited until about 55kph/35mph, and there's no reason to think the D won't address that. I'm still comfortable with my assumptions. The actual big assumption is that Tesla doesn't artificially limit performance to make the S look better at least until the S refresh....
Correct, and the Standard dual motor cars do not double the torque values:Only the Performance cars have the large rear motor. The standard dual motor cars have the same smaller motor front and rear.
and the Performance dual motor cars do not double the torque values:
- 70/70D torque is 325/387 lb-ft.
- 85/85D torque is 325/485 lb-ft.
- P85/P85D torque is 443/687 lb-ft.
Thanks for those numbers to play with, you actually prove me right, unknowingly.
Well, the rear motors in the non P non D cars are only used in RWD non-P cars, so of course it's not a doubling - the motors are different for the Ds.
If you look at the P85 and P85D, however, you'll see that there is a gain of 244 lb-ft from adding the front motor. If you take that same 244 lb-ft front motor, and put it in the rear as well, guess what you get? 488lb-ft. Is that mighty, mighty close to the 85D (non-P) why yes it is. From teardowns, does the 85D use the same front motor as the P85D and use it for both the front and rear? why yes, it does.
Why is the 70D only 387? Software. Remember when the 75Ds magically dropped around a second off their 0-60 times while the 100's only dropped 0.1? that's because they stopped software limiting the torque.
Interesting ... how do you explain your torque values for the Model 3?Thanks for those numbers to play with, you actually prove me right, unknowingly. Well, the rear motors in the non P non D cars are only used in RWD non-P cars, so of course it's not a doubling - the motors are different for the Ds.
