I ve had our LR3 rear end flicking out, reverse lock steering.
In compacted snow a few weeks back.
The normal road conditions very planted around corners
The performance has track mode and options for reducing stability intervention. Do the others not have something to turn off traction control then?
Took my m3lr for drive on farm tracks and unable to get a slide on . Is this the only downside of a Tesla
It's still available but quits as soon as the brake is applied or the steering (or both, can't remember)There used to be a trick to activate a so called dyno mode that could turn off traction control... but I believe this is no longer possible ... but if anyone knows an alternative for SR+ or LR I would be interested to know. I did manage a non-smooth 360 drift in the snow in the RWD SR+ (off road) ... the car keeps trying to correct all the time so it's not very elegant but it's sort of possible!!
1) Can only comment on M3LR - Traction is normally great but I did find rear got 'loose' when tire tread was reaching legal minimum. replacing rear tyre rectifiedModerator comment - thread renamed and merged from "SR+ Stability/Drift" and "lack of slide"
I have an SR+ that I got in the spring. Over the summer no noticeable issues powering out of roundabouts and corners. Traction control seamed to handle it. Since the roads have got wet and tyres cold I have had a couple of wiggles from the back end. One big enough to give me a fright. So appart from the obvious remedy of being more cautious with my right foot I wondered two things;
1. how good is the traction control and has anybody ever properly lost the back end or had a serious drift in an SR+?
2. is this much different in the dual motor/ 4 wheel drive versions? Ie is there a stability benefit in the LR/P?
The M3LR interestingly doesn't exhibit this behaviour, it seems to start a 4 wheel drift outwards fairly benignly and simple reduction of power rectifies.
That's possibly due to it's weight. It's a heavy car pushing down on the tyres. Add to that the very low centre of gravity and you have less weight imbalance between the outside and the inside wheels.
Yes, I've had the debate with myself about the risk of regretting buying a second set of wheels/tyres even with my current v low mileage but stay at-home/local kicked in before I could source some wheels and tyres at the end of December...
It's the eternal dilemma, especially in the Midlands/South where full winter tyres would probably be of benefit for maybe 10 days a year. This is why I'm excited for the latest developments in all season tyres. For UK drivers they fit the bill almost perfectly and perform brilliantly in our prevailing conditions, whilst keeping costs low.
Full winters are not just good for snow. The weather has been wet and cold for longer than 10 days and there's a lot to be gained from full winters (if chosen carefully) in these conditions.
I have Vredestein Wintrac Pro winters and various summers depening on how much I'm tracking the car, but I left the Vredesteins on way longer then usual last year and they were still excellent in dry and relatively warm conditions. High performance winter tyres have really come on. The overlap between summers and winters is much wider now.
