If it's after the blower, it will filter all the time, not just when it comes in from outside. That's particularly useful after a heavy Mexican meal...
But that means dust and dirt clogging up the blower cage and air door.
There indeed are zero fuses on the 12v side. All circuit protection is performed solid-state, which in practice means a transistor (MOSFET) is used to switch all the loads, and the body controllers monitor the current going though each of these and in the event of an overload, it just switches off the transistor. It's much faster and safer, and allows a more reliable and easy to diagnose car. It is more expensive, but this was needed to make the M3 fault tolerant to achieve full self driving with confidence.
So every load or group of loads has a current monitor device?
Yep, which means they can see if some circuit starts drawing more power than it should for some reason. (bad connection, etc.)
They did say that the Model 3 has way better remote diagnosis capabilities.
None of this explains how car and driver (?) Was able to do burnouts!
Yeah at first I thought "good they upgraded it" but then when I saw the vent I thought "bummer wet cell instead of sealed AGM". Question, did the terminals have some sort of anti corrosion coating on them? Wet cell lead acid often have terminal corrosion issues.45 Ah 12 V vs the 33 Ah in the S/X. Interesting
Not sure how I feel about the spin on oil filter for the drive unit. A transaxle shouldn't be generating that much debris that it would need a filter.
I'm sure Tesla didn't add cost and weight without good reason, given how far they've gone to save on both everywhere in the car, so it makes me wonder why they did it.
