Opponent?
If I have free, easy access to nitrogen, you think I should avoid it?
If it's free, that's much better and may be worth it, but then the situation arises thus:
- You fill the tires with (free) nitrogen.
- The temperatures drop, along with that the pressure in the tires.
- You want to bring the pressures back up for efficiency, ride, and handling characteristics.
- You now have to find a nitrogen source, which may not be readily available.
Nitrogen filled-tires can kind of lock you into the dilemma of 1) do I fill the tires now with air, contaminating the nitrogen fill, requiring drain and re-fill later, or 2) wait and fill with nitrogen later, but drive until then on under-inflated tires.
I personally think it's more important to always have tires filled properly, and to really do that you need to fill with air, not nitrogen, so that you can always top off whenever needed.
