I'm about 98% ready to pull the trigger on the MPS4 in 255/35 for my OEM Über 20" (sitting in my cart
Totally agree with all the previous comments about the 245-255 vs. a 235/35 fitment on a 9" wide wheel. Since I don't plan on modifying the suspension, I'd like the tires to fill the fender gap a little more, so I want the slightly taller sidewall.
My main concerns:
Clearance
Sounds like no issue based on a few folks who have installed a 255/35 on the factory +34 offset 20" wheels. The outer fender wasn't as much of a concern as the inner control arms, etc., but that all seems to be no issue.
Traction/Stability Control
Seems like the consensus is stay within ~1% of the factory size, a 255/35 is ~2%, but if you set the car for the 245/35 spec wheel/tire setup, that would make the 255/35 ~1% and it sounds like that's a complete "fix" for this.
Mileage
Some impact, but 5-10% I can easily live with (if that's, in fact, the case), if it was over 20%, and certainly approaching 30%, I'd probably start to rethink this.
Noise
I'm __loving__ the quiet of the new ride, so I don't want this to be impacted too much, it's tricky to communicate, since everyone has different tolerances. So some folks say, "Barely any change", a few indicate, "Noticeable, but no big deal".
I think the 255 will look amazing, I mean, a good part of this for me is purely cosmetic, I want a meatier tire, the fenders more "filled out", but not at too much of a sacrifice, especially the 2nd/3rd concerns above.
I'm even thinking of maybe tossing on a 5mm slip on spacer for the rear, to square those up a little more, it would bring the effective offset to a +29, but I think that would be just about perfect for the rear.
