Yggdrasill
A Model 3 will probably spend more time in the <60 kW tier, thus you will pay less. Not a whole lot less, but a little.I think you may be missing the point that larger battery cars consume energy faster than small battery cars when supercharging such that they will get cheaper charges in "per minute" states -- and there are lots of per minute states.
By the time the Model 3 is out, though, the payment scheme may have changed. Pricing may have been adjusted, and there are indications the superchargers will get an upgrade, so you might see one or more additional tiers. You may for instance see a new tier, >150 kW, and it's not necessarily the case that a (base) Model 3 will be able to utilize that amount of power.
Current tech allows a Tesla to charge at around 1.7C maximum, so assuming the Model 3 has three battery options, 50 kWh, 65 kWh and 80 kWh, that would allow these power levels:
50 kWh Model 3: 85 kW
65 kWh Model 3: 110.5 kW
80 kWh Model 3: 136 kW
If Tesla has managed to improve charging to 2C with the new battery tech that will soon be produced at the Gigafactory, the Model 3 could support this charging:
50 kWh Model 3: 100 kW
65 kWh Model 3: 130 kW
80 kWh Model 3: 160 kW
