Hi
New on here, with a Model 3 LR on order, with tow hitch. I have been doing some research regarding towing a caravan, and would welcome any thoughts/advice on the following:
There are certainly many barriers to being able tow a caravan and significantly there is only 1 caravan I could actually consider. Knaus Travelino, with a Maximum Technically Permissible Laden Mass of 900kg. Things to consider:
- It is within the towing capability of the car (Capable of towing 910kg)
- Within the '85% rule' for matching
- Combined gross weight of 2265 + Caravan MTPLM of 900 combined is less than B+E license requirements over 3500
- No idea on caravan nose weight, with a car max permitted of 50kg ish.
- Regarding electrics, M3 manual states 'pins 9-13 are not supported at this time because Model 3 is not currently equipped with brake controllers'. However;
- 'For trailers weighing more than 750 kg, a separate trailer braking system with an independent controller must be used'.
- Range impact, I would assume half towing a big white box
- Supercharger access, unhitch every time when towing could be an issue
- Charging the car when on campsite. 3 pin socket in caravan wont be able to charge the car (and likely annoy the site owners anyway)
