I thought people might appreciate an easier way to tap unswitched power for the Tekonsha no. 119250 adapter and products like it. I noticed that some members suggest tapping into the gray, three-prong plug under the rear bumper cover with switched power, that is available in 2019 Model 3s and later.
eTrailer, where I bought my Stealth EcoHitch, and others suggest running a wire all the way to the Frunk, to attach it to the 12V battery's positive cable terminal.
However, after connecting the Tekonsha adapter to the taillights, here is a much shorter routing inside the vehicle:
1) remove the rear seat bottom cushion - just feel under the front edge for two tabs and slide them toward the left-hand side to lift the front edge, pull the cushion forward and up to disengage the seat belt buckles, and unclip the bum warmers;
2) remove the foam cover on the right-hand side to reveal the end of the battery cable - see photos;
3) Fully lower the windows to avoid being locked out inadvertently;
4) On the touchscreen, touch Controls > Safety & Security > Vehicle Power > Power Off;
5) remove the trim piece next to the right-hand seat back and run an AWG # 12 wire from the Tekonsha's power (positive) lead from the trunk (behind the right side trim panels) through a grommet into the area under the seat to the end of the battery cable shown in the pictures;
6) remove the negative ground strap and wrap it in a rag to prevent it from grounding;
7) remove the nut on the positive end of the cable (see pictures) and attach a connector crimped onto the AWG # 12 wire from the Tekonsha's power lead, then replace the nut and the ground strap.
Replace everything, power the vehicle back on, and run through the Tekonsha's 'learning' protocol.
