Just had same issue with same fix. Part number is exactly the same. Does it mean issue will be back in few years? Hope not, but cable bending same way...UPDATE: Got it fixed today by a mobile repair tech. Replacing the trunk wiring harness (part no. 1068789-00-E) did the trick.
It was covered under warranty. For reference, here's the invoice:
Funny, from all cables it was purple in my case too (and white).My trunk wouldn't open from app, car screen or physical button.
Booked mobile service to come within 1.5 wks (Vancouver, Canada)
Service came and they brought the wrong parts, whoever handled the service request assumed it was the frunk even though in my description I only said trunk (in hindsight i should've said BACK trunk). He did a diagnostic and determined the trunk data wire was not sending a signal so it needed to be replaced. Luckily the tech said he had the part at home and would go do a quick repair for another customer first and come back after hours to fix my trunk.
He came back and it took about 1.5 hrs for him to replace the entire trunk cable bundle, see attached pic.
I feel the service guys really want to help fix customer issues, maybe it's cause they get OT pay or bonuses? Anyway, I was very impressed it was the first time I've used the mobile service.
I am having this problem all of a sudden in my Nov 2018 build Model 3. I went from trunk functioning to only the emergency latch functioning. I already had the rear latch replaced once under warranty in Feb 2020 due to corrosion issues (my trunk seal was also leaking). The notes from that service said they "checked the wiring harness", so I guess it was an item to check already at that point. Annoyed as it is a 10h round trip to the nearest town where they will even do Mobile Service :\Funny, from all cables it was purple in my case too (and white).
I just had this problem this week with a 2018 Model 3. I installed the power lift gate last year so didn’t want to go through the hassle of removing all the equipment before getting Tesla to look at it, so I fixed it myself. Very easy to find the broken wire (it will likely be broken around where it bends around the trunk hinge in the flexible plastic tubing), then it was a straight forward repair, you can compress the plastic tubing enough to get access to repair the wiring.I am having this problem all of a sudden in my Nov 2018 build Model 3. I went from trunk functioning to only the emergency latch functioning. I already had the rear latch replaced once under warranty in Feb 2020 due to corrosion issues (my trunk seal was also leaking). The notes from that service said they "checked the wiring harness", so I guess it was an item to check already at that point. Annoyed as it is a 10h round trip to the nearest town where they will even do Mobile Service :\
Is the damage to the wiring harness visible without taking things apart? Wondering if I should pop the emergency latch and have a closer look?
I had a quick peek yesterday and didn't see anything obvious - did you somehow pull the outer cover on the wire harness back to check? (I did find these instructions on replacing the harness... Tesla MODEL 3 SERVICE MANUAL: HARNESS - TRUNK (REMOVE AND REPLACE))I just had this problem this week with a 2018 Model 3. I installed the power lift gate last year so didn’t want to go through the hassle of removing all the equipment before getting Tesla to look at it, so I fixed it myself. Very easy to find the broken wire (it will likely be broken around where it bends around the trunk hinge in the flexible plastic tubing), then it was a straight forward repair, you can compress the plastic tubing enough to get access to repair the wiring.
I bunched up the silicone tubing as much as I could to see the wiring from both sides, had to cut some electrical tape on the top side to do so (as the wiring harness is taped to the silicone tubing. One of the wires was clearly not as tight as the others so I gently pulled on it and it came right of the tubing. In my case it was a light green wire, it had clearly been pinched and snapped.I had a quick peek yesterday and didn't see anything obvious - did you somehow pull the outer cover on the wire harness back to check? (I did find these instructions on replacing the harness... Tesla MODEL 3 SERVICE MANUAL: HARNESS - TRUNK (REMOVE AND REPLACE))
The first time I could t get in my trunk I had the exact same circumstance. The button in the trunk had corroded and they replaced it. This time for me nothing opened the trunk, which as others noted was solved by fixing or replacing the wiring harness.I do see the same issue on my Model-3. I can open the trunk with Tesla app and from console but the button on the trunk has no effect.
I had a FIAT 500 with same problem and I used to fix them on my own. I never expected to see the same issue on a TESLA !!!The first time I could t get in my trunk I had the exact same circumstance. The button in the trunk had corroded and they replaced it. This time for me nothing opened the trunk, which as others noted was solved by fixing or replacing the wiring harness.
My green wire was broken, trunk button above the rear license plate didn’t function, and you can see a few other cables have some damage. Replaced the wiring harness and all is good
Interesting note about the recall.Trunk would not open on my M3 SR+. Mobile service replaced the harness yesterday with 1068789-00-F. This morning, I saw news of a recall on the trunk harness Recall Report posted on NHTSA. I'll limit using my trunk until I get this guide protector installed.
Yeah the article from the recall showed the same part number you had replaced... I already scheduled to get this looked at before I install my EV Offer power lift gate.Interesting note about the recall.
Per the linked recall document, the recall is specifically related to the failure of the rear camera video cable within the wiring harness, so it’s a tad different than the issue about the trunk not opening. But they very possibly share a root cause.
Ahh I see... Wonder what happens if they cut it and there is no issue... Do they just electric tape it back or provide a new sleeve which I think isn't possible without a new harness right?The mobile service tech that repaired my car cut open the rubber sleeve to inspect the wires. The damage to the wires was not as obvious as those shown in posted photos, but the rubber sleeve did have obvious sharp bends in it.
I'm not sure, but my guess is that they would replace the harness once the rubber sleeve is cut open.Ahh I see... Wonder what happens if they cut it and there is no issue... Do they just electric tape it back or provide a new sleeve which I think isn't possible without a new harness right?
