Short version: Does anyone know how to remove the plastic cover that goes around the Model 3’s steering column?
Long version: A month or 2 ago the plastic cover around the steering column on my Model 3 started occasionally making an annoying “vibration” noise (can’t think of a better way to describe it) while driving at low speeds — mainly around 10-20 mph. It’s almost like the car is hitting some resonant frequency that is causing the cover to vibrate and emit this noise. (I’m pretty certain this cover is the source of the noise since pressing on it stops the noise.)
The noise is not consistently reproducible, so if there’s any way to attempt to fix it myself, I’d prefer that over scheduling a service appointment. However, despite searching online, I haven’t figured out how to remove the cover, which I’m assuming is a necessary first step to fix the noise. (There’s a single screw on the underside of the cover that’s accessible, but removing that screw doesn’t appear to allow the cover to be removed.)
Here’s an audio recording of the noise that I recorded with my phone while driving at low speeds and uploaded to Youtube. (This is a particularly severe example, and I’m holding the phone right next to the cover, so it sounds a bit louder here than in real life.)
And here’s a photo of the cover by itself from an ebay listing:
In the meantime, I’ve wrapped a Velcro strap tightly around the plastic cover, which does a pretty good job at preventing the noise. But that’s just a band-aid solution and I’d prefer a more professional and permanent fix.
Any help or insights would be appreciated. Thanks!
