Got caught in a flash flood today due to the thunder storms on a B road near my home. I was following a Mini and we hit flood after flood. In theory a Tesla is a great car for flood water since it has no air intake or exhaust but it's also a pricey piece of kit to drown. You have to keep the speed very low though or lose your undertray ( as I previously discovered). I worked on the principal that anything a mini could handle so could I. Eventually we reached what I knew would be the last and worst place and it looked a bit deep but the Mini had gone through so knew it would be OK. I set off into the deep and then caught a flash of movement to my left. At which point I realised the mini hadn't gone through but had bottled it and taken a left just before the bridge!! Turned out it was quite deep. Between 18 inches to 2 feet based on the footage and the fact it was lapping almost upto the frunk opening.
The good news is I made I through. No adverse effects ( so far) except some very dirty door shuts/sills. It's not something I would recommend but it's good to know the car can do it if needed
