Useless effort. If you run into a "suspension and related parts" issue, are you going to swap back in the stock parts before you bring it in for the hypothetical warranty service? Otherwise, I think Tesla's probably going to notice when they go to do the repair. At which point, if they want, they'll claim you voided the warranty.Where to get wheel alignment in Southern California for the Model 3 outside of the service center? I lowered the car and I don’t want Tesla to void my warranty on suspension and related parts.
Thanks!
Wanting to find a good a non-Tesla alignment shop because they might be cheaper or faster than having Tesla do the work, could be worthwhile though.
i just got my car not to long ago (maybe a month?) and recently hit a really big pot hole and the car has been driving very rough (very bumpy\rough, slight veer right)
Didnt want to create a new thread on this
But, i just got my car not to long ago (maybe a month?) and recently hit a really big pot hole and the car has been driving very rough (very bumpy\rough, slight veer right) since. Im not a car guy so not sure what the issue is, alignment\balance? would this be a suspension thing?
Either way,I tried to call the service center here in san diego to ask about an alignment and they wanted something like $325-350, is that normal? I know on previous cars i would just go to firestone or a local place and it would be less than 100 (or $200 for lifetime at firestone), so this seemed a bit excessive and was wondering if anyone here was in San Diego or SoCal that could recommend a good place to get this looked at?
Thanks!
Yeah i was worried about that and tried looking around the outside of the rim but didnt see any dents\damage, so HOPING its just an alignment\balance issueI would check and see if you damaged/bent your wheel before doing an alignment.
As @RZRZ mentioned, check for damage to the wheels. $325 is the quote I got from Tesla. I guess this is the going rate. But in case you need your car aligned, I went to a wheel/tire shop in San Gabriel, CA and got mine aligned. Fixed my alignment issue. Good luck!
Hmm Thanks, thats good to know,I used Big O Tires. They know how to service Tesla, in particular how to keep the car in Neutral.
You can get the alignment checked against for six months.
(Something I would recommend if you live in an area infested by potholes)
It was in Northern California, but the Rep. printed out from his computer the whole process for dealing with the Model 3.Hmm Thanks, thats good to know,
which Big O did you go to?
When the Towing mode is used, Un-clipped the parking brake harness so that the parking brake will not engaged. See attached.It was in Northern California, but the Rep. printed out from his computer the whole process for dealing with the Model 3.
So this is something you can check. The issue is that the parking brake should not be used when doing the alignment.
The car should be in Neutral, but as soon as you open the door the car goes back to Park.
You can use the Towing mode, but it resets after 20 minutes and goes back to Park.
So there is a special process for keeping the car in Neutral.
I guess, you need to remove both rear wheels?When the Towing mode is used, Un-clipped the parking brake harness so that the parking brake will not engaged. See attached.
Hello,Where to get wheel alignment in Southern California for the Model 3 outside of the service center? I lowered the car and I don’t want Tesla to void my warranty on suspension and related parts.
Thanks!
