hk23
28
16
SoCal
What color is your car? The Watkins are pretty sweet also.
Black.
Seems like the Watkins are on backorder in the 19 x 8.5”. The 19 x 9” set are in stock, but concerned about potential rubbing and poking from the front (on 245/40/19 tires) if I end up not deciding to not lower the car.
DNAPoPo
253
188
Orange County/Los Angeles, CA
Black.
If you dont lower, no rubbing, I can raise my car to stock height and no rubbing for sure, not much poke, pretty flush at +30 with that width
299792458
115
97
Colorado
Received these Ohm Lightning (Gloss Black) 18 x 8.5" wheels with Michelin X-Ice Xi-3 235/45/18 winter tires. Exceed my expectations, these wheels are fantastic. They clear the performance brakes and weigh ~22 lbs, machined to fit the P3D hubs without any adapters or rings. Clearance between the calipers and the wheels is roughly (one fingertip). I should measure more precisely, but it's probably between 5-10 mm. Still waiting for the TPMS to be detected, but hoping they register soon. Shout out to Jason @ GetYourWheels!
Please excuse my dirty discs in these photos, just went through a couple of snow storms with grit and grime on the roads, and of course haven't applied the brakes much with the sorta recent improved regen update. Ran to the car wash after installing the new wheels and snapped a few photos. I'll take it out tomorrow and stomp a little to make them sparkle.
Reactions: [email protected]
Jaiey
11
3
New Jersey
That looks great. I am making this change soon after going through a pothole and damaged the side of front tire Any changes in handling, efficiency, or ride quality? And did you use any spacers or hub centric ring to have the flush OEM fit?
299792458
115
97
Colorado
Less traction for sure, so far only noticable on dry roads with spirited driving. More efficient for sure, but I don't have any good comparison data points other than looking at energy usage and seeing less usage per mile for particular routes. Finally, no spacers or rings with these wheels (ordered specifically for P3D and they were machined to fit).
Reactions: Jaiey
Jaiey
11
3
New Jersey
Sweet. I will be ordering 18" Ohm Proton Wheels for P3D+ to replace 20" wheels. I will share the feedback and pictures ones I install.
Was the TPMS detected? Asking to see if I should consider buying any other brand
299792458
115
97
Colorado
Ya, next trip after posting, the TPMS picked up and started displaying. Seemed more accurate too than the factory units lol.
Apr 9, 2014
1,001
236
Santa Fe Springs, Ca
View attachment 491285 View attachment 491286 View attachment 491291 View attachment 491292 View attachment 491289 View attachment 491290
Thanks for sharing the pics, these came out great! Perfect option for 18"s to fit over the Performance brakes. Looking forward to the new pics ;)
Im planning on purchasing a 18x9.5 25+ dekagram konig ,I plan on mounting this with a 275/40/18. Does anyone know if i'll encounter an issue witht his offset?
I tried calling get your wheels today, unfortunately it goes straight to voicemail.
Thanks!
Steve
Cricket88
351
455
Los Angeles
Thanks!
Steve
That might work on the rears but the fronts will poke out past your fender line if you’re doing a square setup. If you lower the car you will rub for sure. Also the profile on that tire might be too tall if you’re doing 275 all around
Tricked
20
6
Tampa, FL
Quick shots of VS Forged VS02 in brushed titanium. 19X9 +32 with 245/40/19 and 19x10 +38 with 275/35/19.
Need to get better shots with more angles.
TWG_Vinny
New Member
Feb 14, 2020
Hey all I’m new to the forum and picked up my model 3 in December. I’m a huge car enthusiast but new to the Tesla world. I got Eibach Pro lowering springs coming in but I’m curious on some of these wheels set ups for staggered set ups since even on my track Miata I run a square set up. I’m wondering if these will fit okay. Thanks in advance, I’ve been lurking the forum since October haha.
19×8.5 +38mm / 19×9.5 +38mm
Tricked
20
6
Tampa, FL
The 8.5 for the front will only stick out 2mm from OEM.
The 9.5 for the rear will stick out 14.7 mm from OEM.
I have seen as much as 24mm front and rear, so you should be good with that fitment.
