Vendor Model 3 Wheel Fitment by GetYourWheels
Discussion in 'Model 3' started by [email protected], Nov 17, 2017.
  1. Tricked
    Tricked Member
    Tampa, FL
    I used Lamin-X. However, Stek DYNOshield is a much more clear film. Not as much texture with the DYNOshield. Lamin-X on the headlights will show the texture in the beam.
  2. Laa1121
    Laa1121 Member
    Maryland
  3. Scrive08
    Scrive08 New Member
    Victoria, BC
    19x10 +30
    19x11 +13
    I’m wondering if this setup will work.
    Stretched tires, Coilovers, sr+
  4. 299792458
    299792458 Member
    Colorado
    So yesterday I decided it was time to remove swap my all seasons tires/wheels (mounted on the factory 20" performance wheel) back and remove my Ohm Lightning wheels with the Michelin winter tires. Haven't really driven much since March and summer is creeping up on us already.
    All four wheels were stuck to the hubs and I could not yank them loose! I had to use a BFH with several whacks to get the wheels off. Now I'm concerned something wasn't right, because I remember too that they took many turns to torque down correctly when I installed them. What could have happened here, was something not machined correctly, and did they not mate correctly to begin with? I don't think I want to put them back on again!
    Pics of wheel and hub attached.
  5. Josh@GYW
    Santa Fe Springs, Ca
    Sorry to hear about the issue, can you please send me an email and so we can look into this and get this figured out for you asap? Thank you! [email protected]
  6. N54TT
    N54TT Member
    NY
    it looks to me like that the wheel doesn’t have the proper hub lip clearance. I would also wire brush your hub and throw on some anti seize to help prevent rust hub syndrome lol.
  7. NJturtlePower
    NJturtlePower Living the Dream, Driving the Future!
    New Jersey
    Late post, but got my Stance SF07's from Jason at GYW a few months back...
    The rims are 19x8.5 +35 square setup wrapped in General GMAX RS 245/40/19 summer rubber. They are flow-forged and a few pounds lighter than the Tesla 19" Sport wheels. Loving them more and more especially with my recent Eibach Pro-Plus kit install. :D
    • Love x 2
  8. Josh@GYW
    Those look fantastic, the SF07 suite the Model 3 perfectly, thanks for sharing!
  9. tlr1000
    tlr1000 Member
    Vancouver
    The SF07s look similar to the Vertini RF1.2s - also from GYW. vertini 1.2.jpg
  10. srk67
    srk67 Member
    NorCal
    What is the weight of the cf10s in a 19x9?
  11. Josh@GYW
    We dont have exact weights, but we'd say approximately about 24lbs! Let us know if you're interested in a set
  12. srk67
    srk67 Member
    NorCal
    Definitely interested, but holding off a few months for ordering. Do you guys normally run specials around black friday?
  13. Josh@GYW
    Forgestar has in the past, but I asked them and they said they dont have any info right now on if or when they'll be running any sales yet.
  14. aspec818
    aspec818 Member
    Bay Area
    Looks nothing alike..
  15. srk67
    srk67 Member
    NorCal
    Thank you for checking. What is normally the lead time on these?
  16. Josh@GYW
    Right now their builds are taking about 6-8 weeks on average, but that can very depending on the availability of their blank parts
  17. srk67
    srk67 Member
    NorCal
    Do you guys keep any SKUs in stock?
  18. Josh@GYW
    We dont, all Forgestar wheels for the Tesla are made to order
  19. srk67
    srk67 Member
    NorCal
    Would you recommend a +35 offset on a 19x9 wheel if I plan on using 255/40/19 tires?
  20. Josh@GYW
    If lowered that should fit pretty well, if on stock suspension the fronts might poke very slightly, but it shouldnt be too bad
