Widest you can safely run on the 8.5 wheel is a 255. 255/40/18 would be 1% undersized so you would be just a little off in comparison with the 20" package.
Tesla Model 3 come with protruding rotor set screws (see photo). This is different from Models S and X and creates problems with the after-market rims. GetYourWheels photos suggest that these screws were simply removed. Is this safe?
That screw has no purpose other than to keep the rotor on and lined up during assembly. You can remove it.Tesla Model 3 come with protruding rotor set screws (see photo). This is different from Models S and X and creates problems with the after-market rims. GetYourWheels photos suggest that these screws were simply removed. Is this safe?
See this post: Group Buy Poll for Mono-Block Forged Alloy Wheels by Titan 7I just ordered a P3D over the weekend and have started looking at wheels. I'm a more track oriented person and would like to keep with a square setup. I'm noticing that the rear fitment can take a lot more wheel which I'm not interested in. For the right fitment with a square setup I either have to go really aggressive up front or throw some spacers on the rear. Another option is to order a rear rim with a lower offset and at the very least keep the same size tires.
A couple questions if you don't mind:
1. What is the most aggressive you can get up front keeping in mind 1-1.5" lowering?
2. How long are the wheel studs? Can you fit a 10mm spacer on it or would that not leave enough thread showing?
3. Pending on question #1, i'd like to go with 255's or 265 all around. What would be the best f/r combo with the wheels at least being the same width (so I can keep circumference the same)?
Nice. Good to hear that they fit! I just ordered some Enkei Raijin 18x9.5 +35.Rather then +30 in the rear, +35 with a 5mm spacer might be better to keep that perfect flush look, so you can rotate the tires. But even +35 without the spacer looks pretty good. See picture. This one is 9.5 +35 all around with no spacers.
View attachment 332462 View attachment 332463
That wasn't my car. I saw that car at a Mountainpass Performance meetup. But I am getting a similar square setup in 19": 265/35 19 tires on 9.5 +35 wheels in T-S5 Forged Split 5 Spoke Wheel so I can fit MPP Page Mill 365mm Big Brake Kit which 18" are to small for.NICE! You're like Enkei buddies with our guy in Hawaii
18X9.5 all around with 265/40/18.
Mountain Pass Performance is running 19x10 + 35 with 275/35 tires and they claim it didn't rub even at opposite lock (drifting).That looks like it might rub on cornering
