Going off of those wheels sizes & offsets, they should fit on the Model Y. The only issue might be the clearance behind the spokes and the brake caliper, but while the Model 3 and Model Y calipers aren't exactly the same, they are very similar in size & shape so if it fits on the 3 than it should most likely fit on the Y. You might also want to check the load rating on the wheels as well, which should be stamped on the back of the spokes, but in most cases you should be fine with this.
If you already have tires on them for a Model 3, then your speedo will be off since the 3 uses a lower profile tire than the Y.
