Model 3 Wood Trim Major Creaking
I am getting major creaking noises coming from the wood trim in my p3d. I know it's the wood trim because if I put a little bit of pressure on the trim, it makes the same sound.
Does anybody else here a creaking sound if they put slight pressure on the wood trim near the passenger side?
Also, anybody have a fix/solution for this?
Reactions: SlimJim
Its extremely easy to remove.
Don't forget to remove the end clips first.
Reactions: cochran
I had the same issue and I would also clear/break off the messy plastic welding pieces under the dash once removed in addition to felt taping all plastic on plastic contact points. Once I did this I stopped hearing the annoying creaking noises
