I am going to swap the front motor of a salvage Model S with an LS4 V8 engine, space permitting. I see many advantages to such a build, what do you think? What would it be worth when done? I look forward to your thoughts.
Rich of Rich Rebuilds has the same project in work. See his YT vids...I am going to swap the front motor of a salvage Model S with an LS4 V8 engine, space permitting. I see many advantages to such a build, what do you think? What would it be worth when done? I look forward to your thoughts.
I have. I'm not doing what he's doing. My build will retain the rear electric motor and all Tesla systems.Rich of Rich Rebuilds has the same project in work. See his YT vids...
Far less than the time, effort and money you put into it, much like any custom rod.I am going to swap the front motor of a salvage Model S with an LS4 V8 engine, space permitting. I see many advantages to such a build, what do you think? What would it be worth when done? I look forward to your thoughts.
Part of it is eliminating range anxiety. Ultimately it's how I think a performance car, not to mention hybrid, should be configured.Is the goal for longer range like a Frankenstein PHEV?
That is my concern, but I think I can do the build for $30k. Of course I'll do much of the work myself.Far less than the time, effort and money you put into it, much like any custom rod.
You could put some fake pipes in the back, a boom box playing V8 exhaust sounds, and a 120 v generator for range extention.I have. I'm not doing what he's doing. My build will retain the rear electric motor and all Tesla systems.
Fair enough. I'm planning using on a 60D with no sunroof to offset some of the weight. Keep in mind a D car has a motor up front already and configured for front wheel drive handling. I figure active air suspension will help also. Gas tank will go in rear sub floor storage compartment. Sadly side pipes will have to be used for exhaust.I'd think the driving dynamics would way off. Seem like it will be way nose heavy. Not sure where you intend to put fuel tank or route exhaust system. From a frontal impact safety perspective, realize you've just totally messed up the front crumple zone and any significant impact your likely to have the engine in your lap.
So other than for the novelty of it, I honestly don't see the purpose and personally value to me as a potential buyer would be zero. Maybe if you can find the right person it would have some value, but I wouldn't be doing it because you think you'll recoup your costs.
Just my two cents worth, but then I'm not into novelty vehicles.
A FWD performance car?Part of it is eliminating range anxiety. Ultimately it's how I think a performance car, not to mention hybrid, should be configured.
Money pit. If you want to invest 30K, you're better off buying Tesla stock.what do you think?
Part of it. Ultimately it's how I think a performance car Southold Southold shouIs the goal for longer range like a Frankenstein PHEV?
Yes, I've been playing around with this for awhile. I think the LS4 is the missing piece.A FWD performance car?
With the battery you won't be able to fit a driveshaft to the rear wheels.
Tesla's motor will also fight with the front engine, and you don't have room for a gearbox. Also, the missing front motor will give you errors in Tesla's system.
With side pipes and gas tank behind the rear axle this thing would be hilariously unsafe and bad for the environment.
Also, you've asked the same question in 2017. Nothing much changed in 4 years?
Tesla Hybrid 600 Mile Range
Hello All, I have rebuilt half a dozen Teslas from salvage. That being said I am considering converting a single drive Model S to an all wheel drive hybrid. The concept is simple, replace the front end of a single drive Model S with a dual drive frame rails/hardware and add an ICE to drive the...teslamotorsclub.com
Rich is doing it for the Youtube views, not to make an actual product anyone would want.
It seems you have an idea, and haven't found a customer for this idea yet. Now why would that be?
This is one of the reasons I'm picking that motor. There is lots of information on these engines.I am car/motorcycle junkie but I think this proves the LS swap is out of control.
what do I think? I think this post was made 24hrs after you meant it to be posted..I am going to swap the front motor of a salvage Model S with an LS4 V8 engine, space permitting. I see many advantages to such a build, what do you think? What would it be worth when done? I look forward to your thoughts.
?what do I think? I think this post was made 24hrs after you meant it to be posted..
I think so. But even more fun at superchargers and the track! Now that I think about it, I could supercharge it also! :->Nice! Good luck, should be a fun project.
