2017 S75D AC issues here too.
Symptom: HVAC struggled to cool cabin air. No issues with fan control.
Frequency: Twice, ~6 months apart. Oddly enough, both after the car was parked & plugged in for a few days (airport).
Diagnostic Problem: Each time it happened I called into Tesla so they could pull logs. The first time the situation resolved itself the next day and the SC reported upon followup this was a known issue and they were working on a firmware patch. The second time the same thing happened (issue resolved itself after ~24hrs) but I noted the AC seemed to struggle to keep up with Houston's heat. Made an appointment with SC for manual inspection.
Further observation of the car prior to the SC appointment revealed if the AC was switched on via the app to pre-cool the car, the cooling fans would be on FULL blast (think Supercharger level!) just to cool from ~100 to ~77. Certainly not normal and did not match up to my experience the prior summer where you would hear the fans operating, but not at that level.
SC Diagnostic: the valve (or whatever the thing is called) regulating outside air (HOT) vs using inside cabin air (COOL) was partially faulty. Faulty component was replaced. Specifically asked if the logs showed any issues with battery temperature, SC reported they did not. The system appears to be working normally now.
Further comments: I've noted when I pre-cool and start driving, the outside temperature gauge will shoot up by ~10 degrees and then slowly start to come back down. This only seems to happen when I do pre-cooling. Unsure if this is normal or not.
