If you don't mind my asking, how did you remedy the cold feet issue?
I'm wanting to finish some more experiments which I think will
solve it, but for now, I'm using a band-aid. That's why I didn't explicitly already post my solution.
Here's what I think will solve it, written in English as a second language, so I'm still trying to figure out what they mean:
My feet are freezing!
What I ended up doing was getting an electric blanket that plugs into the cigarette output (lots on Amazon). The problems with the electric blanket, though, are:
- I have to be extremely careful not to let it interfere with the pedals (brake and accelerator).
- I can't get it wet.
- The cord could easily tangle up my legs; it has to be kept down, out of the way.
- The one I got is way too large.
But, with careful blanket management, I've found this band-aid to actually work, except on the longest and coldest of journeys. It's night and day, though, so it's not a bad band aid as a first step.
What I want to do is remove that aluminum plate mentioned in the message above, put in the insulation strips (I already have some insulation strips for that sort of thing), put the plate back, caulk around it if necessary, and then get a smaller electric blanket which will fit underneath the matt and under the brake and accelerator pedals and attach it down with some sort of velcro. I haven't done any of that. It's a work in progress. If you do get the electric blanket, be SURE it will not interfere with the pedals, or cause you to trip getting in or out of the car.
The reason I think the message above is accurate is that I have measured the air temperatures just the way he did, and came up with the same result and the same conclusion without actually seeing any plate there. The fact that he found a plate, insulated it, and solved it just confirms my hypothesis (and his). I think that is step #1 in any real permanent solution. (Yes, this points to bad design by Tesla!)
