Model S 2022 - charging door does not open if pressed - normal?
I picked up Tesla Model S 2022 recently and I have noticed that my charging port door does not open if pressed. We have model Y, which has similar design of charging port door and it DOES open if you press on it but not on model S.
I visited local Service Center today (for another issue) and I asked about this but the technical advisor told me that it is a feature of the model S refresh that the charging door does not open if pressed since Tesla changed the door design. Somehow, he was not very convincing to me and it just sounds weird to remove such a useful feature.
Can someone with refreshed S chime in and let me know if you charging door can be opened by pressing on it?
I just reviewed the manual for my car and based on it, the door should be opened if pressed.
DerbyDave
2,894
1,717
Kentucky
You evidently have a car later than a refreshed. You have a redesigned refresh, which has a new port door for cars built in the last few months, with the redesigned rear end and matrix headlights. You need to get someone with the redesigned rear lights to check. Which refreshed do you have?
I have a 2022 with the new charge port door and I, too, have been unable to make it open by pressing it. When charging at a CCS station, I've had to open it from the touchscreen. Kinda annoying.
It is annoying indeed. My prior experience was opening it from the screen or app but it sometimes closes before I insert the charger.
Have you tried pressing on the wider section of the door (towards the rear)?
What charger were you using to charge/open the door? Interestingly, there is something "different" about the charge door protocol for mine as well. I am on my 4th Model S with same Gen 2 wall charger. Every prior car has opened no problem, but now I have to hold the charge button for 10-15 seconds and it will open. I am waving it around a bit and it will work. I asked service check and they said try different charger. I tried my new mobile charger and it opened immediately, everytime. Also at supercharger, opened immediately, weird. Maybe the wall protocol is slightly different.
No charger. If I use chargers, the door opens just fine.
My door does not open very well when I press on it. The way it looks is it sits too deep and there is not much space to press it down before it opens.
Do you have another car you can try that charger on? I've got two Gen 2 wall chargers and a brief push of the button on either opens the charger door on both our Ses (2015 and 2022). It doesn't work as reliably on our 2022 Model Y, however. (The Y is generally much slower to respond to open the charge port door—charger button or pressing on the door—as was our Model 3 before it. This despite our Model Y having the Ryzen computer in it.)
WilliamG
Hinge Fanatic
Apr 20, 2019
6,535
10,433
Seattle, WA
Yes the new-design S is slower to open than my old S, which was pretty much instant the second you click the button, and this seems to rev a motor up before it opens, but it always opens (just about a second-or-so slower). Also, for those that care, here's a video of it opening manually. And BEFORE ANYONE SAYS ANYTHING, yes, I have a charger penis in the reflection. I needed both my hands for the video/activation of the charge port door, so get over it already. 😅
I have the same problem with my refresh refresh S with the new lights and charge port. The door won't open when I press on it (regardless of where), and it also won't open when I push the button on the charger handle, regardless of old or new mobile charger, even superchargers won't open it. The service center confirmed this and said it's a problem with the ECU, but they weren't able to fix it yet because the part is not yet available. I recommend making a service appointment through the app.
Reactions: WilliamG
WilliamG
Hinge Fanatic
Apr 20, 2019
6,535
10,433
Seattle, WA
Did it ever work for you? I assume you can open it from the screen in the car or from the app?
