I think someone asked this the other day, I'm about to do a range trip so change to range trip and plugged it in....however my car will only go to 363km's...even though it's meant to go to 420km's..... Would this be because k my car set to typical km's rather than rated? -ECIT
Probably. Change to rated and see what you get. Keep in mind that you probably won't achieve the typical unless you drive VERY conservatively.
I think I must drive like a granny cause I often get a 178kw/h for the last 50km on the dash... -ECIT
I think that must be typical ECIT, as I get 390km indicated (rated) on my S60 for a full charge. Although typical tends to be 75-80% of rated so that seems high. Might be a calibration issue if it's the first range charge you've done.
