We have a P85 that has about the same range as a 75D.
Based on our experience with a 2500 mile road trip in the summer, we're planning to get a 100D (if/when available) to make future long road trips easier. There were several hops between superchargers when we had to manage the energy more carefully by slowing down to stretch the charge far enough to make the next charger.
A couple of factors when looking at the rated range.
- Factors like wind, elevation, precipitation, heavy traffic (speed up/slow down) will all impact range (mostly decreasing the range)
- You want to avoid exhausting the battery, we typically try to keep the charge above 7-10% when reaching a charger
- Most charging is typically to 90% (or less), and charging above 100% frequently may affect battery life - and certainly takes much, much, much longer at superchargers
- Driving at typical highway speeds (75+) consumes more energy and reduces range
- Battery packs degrade over time, with most owners reporting degradation of about 5% and then stabilizing there
When planning trips, I estimate the distance between chargers so I'm aware of which legs where I may need to monitor energy usage.
Our P85 was originally rated for 265 miles. We've lost 5% of the battery, reducing that to around 255. When driving on the SC network, we typically want to keep the charge between 10-90%, reducing the range another 20% to 205. And in normal driving conditions at typical highway speeds, we consume energy 30% faster than the rated range, reducing the effective range (for planning purposes) to 144. And if we anticipate strong headwinds or cold weather, we'll adjust the effective range downward even more.
And after many short road trips (350 to 600 miles) and one long road trip (2500 miles), these estimates have served us pretty well, helping us to project when we need to get extra charging at superchargers and when we may need to slow down between chargers.
Using our estimates, a 90D increases the effective range from 144 to 156 - and while that 12 miles may not sound like a lot - when trying to navigate the supercharger network, that difference could be significant in helping to maintain highway speeds.
And, assuming a 100D gets 340 miles of rated range, it would have an effective range of 181 miles - probably enough to eliminate energy management (slowing down) in most cases when travelling on the SC network.
Of course you can increase the range by slowing down (such as driving at the posted speed limit, which is typically slower than most of other highway traffic) and there may be other techniques you can use to stretch range further (such as driving manually, not using the cruise control, changing the air conditioner/heater settings, driving behind large vehicles, ...).
It is possible to take long distance trips with an S60 - and we've seen 60s stopped at the superchargers when we've been travelling. The difference between having an S60, 75D, 90D or 100D is not the ability to take the long distance trip - it's in how long those trips will take. The larger battery packs will allow driving at higher speeds and will have shorter charging times - both reducing the time required to take the trips.
But if almost all driving is local - and an S60 or 75D is all that's needed for most local trips - then you can save a lot of money by buying the battery pack size you need for most driving - and accept that the occasional road trips might take a little bit longer.
