someone on reddit with a 2014 P85 has photos of their car hitting 128 kW at a supercharger and it looked like the charge curve/taper was different. This is on 2019.20.2.1. Anyone else seeing this?
My 90D hit 145kw once I updated to 2019.16.2. I routinely see above the old limit of 116-118kw.
What's your charge percentage when you start charging?
I am too scared of going below 10% so I usually make it to SCs with 12-14% and I get about 120kW for a few minutes on my 85D.
I was around 32% or so when I charged last night on 20.4.1 and hit a peak of 116kW right off the bat but it immediately tapered down to around 101-105 and stood in the 90's for a while. Before my best was 97kW.
Got my own confirmation! Before today I’ve maxed at 118/119 kW.
2014- D pack.What battery pack and year of car do you have?
Have you noticed and loss of range recently?
2014- D pack.
No significant loss of range. About a month ago 100% was 250. As of today it’s 249. I’m assuming it’s just normal degradation.
2014- D pack.
The taper was quicker than normal, but I think that was due to a few variables - first, when I was driving there it was 90 degrees out. Second, the speed limit is 80 and I was doing between 85-90 most of the way there so the battery was really hot. Lastly, I had someone pull into the stall next to me right around 35-40% I wasn't paying enough attention to see if that made my speed drop or not. It said 1 hour to get from 5% to 90% and it actually took an hour and 6 minutes, so close, but I'm not sure how much that was impacted from the three things I mentioned above.Did you notice how the taper went?
My only "solid" data point for my 2014 85 D-pack is that I usually go under 100kw at 80 miles of range.
Regardless of the taper, the more Kw, the better.
This was my taper from yesterday. Please note what I mentioned in my previous post about thinking it's tapering quicker than normal in this case.
Comparing it to the the chart from Tesla Battery Charging Data from 801 Cars, in my case the taper obviously occurs way sooner than other cars. I'm curious too see what others have with their cars and how this new charge curve impacts them.
Just hit 127kw on my 2017 S75 with 20.2.1. Easily the highest I’ve seen yet. This was from about 20%-35% SoC on a navigation route with the supercharger as the destination, so I assume en-route battery prep applies. It ramped down after about 35% but stayed above 100 for a bit. By the time I got to 50% it had dropped below 100 and tapered from there. Overall I’m thrilled with the new profile - huge jump from old charging limits. Note, my car definitely sounded like it could take off and fly the rest of the way with the fans while supercharging, but otherwise went great. — Dan
